Validating a checkbox group
Thread begun 4/07/2010 11:05 am by spideydan294696 | Last modified 4/07/2010 12:39 pm by spideydan294696 | 2284 views | 4 replies |
spideydan294696
I keep getting an error when I submit my form for those form elements that are multiple checkboxes with the same name/ID. I have a checkbox group to allow multiple selections of those checkboxes (only 1 needs to be checked to be valid). Am I receiving this js error (object doesn't support this property or method) because I have multiple checkboxes with the same name? And if so, is there a workaround to make this error-free?
I am using ASP/vbscript.
please send a link to your page where I can see the problem occur to be able to investigate the cause.
spideydan294696
Here's a link to a test instance:
validationtest.asp
In the Show validation Errors behavior, you need to uncheck the "Set Focus to first invalid field" Option. Since you check boxes all share the same name, it cannot determine which one is the first invalid field on error.
spideydan294696
Thanks Jason - that worked!
