Installation Problems
Thread begun 4/07/2010 9:36 am by info401163 | Last modified 4/07/2010 4:22 pm by Jimmy Wu | 2737 views | 3 replies |
info401163
I am tying to install the PowerStore 3 on a virtual testing environment on a windows based server. We have successfully installed PHP on this server, and have passed the check on step 1 of installation. However, after entering the database credentials in step 2, when I click on "Go To Next Step", I get a blank page, no errors, just blank. Any suggestions?
when a page displays blank, it means a php error has occurred, but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
info401163
No luck
That did not help, still a blank page.
Which page did you put the code on and what page is in the url when you see the blank page?
