eCart checkout wizard error
Thread begun 3/09/2009 4:50 am by te_araroa319945 | Last modified 3/12/2009 3:15 pm by Ray Borduin | 6428 views | 6 replies |
te_araroa319945
Hopefully someone can help with this!!
When running eCart Checkout Wizard,on the Payments Section Step 1 of 1,I enter my pay pal member ID click next and receive this error - 'While executing onMouseUp in WA eCart CheckoutWizard.htm, a JavaScript error occured'. This message appears twice, and I can't get any further. I'm using Dreamweaver CS3 and eCart version 4.1.5. This has only started happening since i downloaded and installed the latest version. Previous version worked fine.
Thanks for any help
Colin
You are the second user to report this problem. We don't know the solution yet, but I would like to look into it with you directly if you are available.
Please post a support incident including your phone number and reply to this message with your incident ID. I will contact you to resolve this issue directly.
te_araroa319945
Hi Ray,
Thanks, Here is my Ticket number 82859.
Colin
CraigRBeta Tester
error in pages.js
is this the same javascript error which was caused by line 310 of pages.js ?
i logged a support ticket for this problem recently and was provided with an updated js file
That is possible. I haven't had a chance to look into it yet so I don't know. Thanks for the suggestion though, I'll check early to see if that is the problem.
mark321888
Make that 3 people that have had this problem.
I'm at a standstill on my development now.
Haven't called in. No ticket number.
Waiting to see what happens in this thread.
Try the solution listed at: showthread.php?t=145
I think it is most likely the cause.
