DFP2 Not uploading image
Thread begun 5/20/2009 8:39 am by mike264653 | Last modified 5/20/2009 12:20 pm by Ray Borduin | 4448 views | 6 replies |
mike264653
I am running DFP 2 with DW CS4 on a mac using MAMP as a testing server. I created a database in MySQL and my admin pages with DataAssist 2.0.4 using the DA Wizard.
I reviewed the DFP2 PDFs and looked at the DFP1 videos to see if I missed something but I can not get a file to upload. All the data is sent and captured in the db but my folder for my uploaded images remains empty. Here is the code for the file.
DFP1 worked great, I can't see whats broken here.
Thanks for any help you can give
<?php require_once("../Connections/frubob_db.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1_1 Start
'UploadFolder' => "upload_Images/photos/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "1",
'ResizeWidth' => "500",
'ResizeHeight' => "325",
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "upload_Images/thumbs/",
'FileName' => "[FileName]_thumb",
'ResizeWidth' => "75",
'ResizeHeight' => "50",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
WA_DFP_UploadFiles("WA_UploadResult1", "image_name", "0", "", "JPG:80", $WA_UploadResult1_Params);
if (isset($_POST["Insert"])) // Trigger
$WA_connection = $frubob_db;
$WA_table = "photo";
$WA_sessionName = "WADA_Insert_photo";
$WA_redirectURL = "photo_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "photo_id";
$WA_fieldNamesStr = "sender_name|sender_email|image_title|image_name|upload_Date";
$WA_fieldValuesStr = "".((isset($_POST["sender_name"]))?$_POST["sender_name"]:"") ."" . "|" . "".((isset($_POST["sender_email"]))?$_POST["sender_email"]:"") ."" . "|" . "".((isset($_POST["image_title"]))?$_POST["image_title"]:"") ."" . "|" . "".((isset($_POST["image_name"]))?$_POST["image_name"]:"") ."" . "|" . "".((isset($_POST["date"]))?$_POST["date"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,NULL";
$WA_connectionDB = $database_frubob_db;
if ($WA_redirectURL != "") {
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/AdminTemp.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<!-- InstanceBeginEditable name="doctitle" -->
<title>Insert photo</title>
<!-- InstanceEndEditable -->
<link href="../css/frubob.css" rel="stylesheet" type="text/css" />
<style type="text/css">
</style>
<!-- InstanceBeginEditable name="head" -->
<link href="../WA_DataAssist/styles/Refined_Moab.css" rel="stylesheet" type="text/css" />
<link href="../WA_DataAssist/styles/Tahoma.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="globalContainer">
<?php include("includes/admin_header.inc"); ?>
<div id="middle">
<div id="pic"><img src="../images/side_bg.jpg" width="234" height="474" align="left" /></div>
<div id="content">
<!-- InstanceBeginEditable name="Content" -->
<div class="WADAInsertContainer">
<form action="photo_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Sender's Name:</th>
<td class="WADADataTableCell"><input type="text" name="sender_name" id="sender_name" value="" size="42" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Sender's Email:</th>
<td class="WADADataTableCell"><input type="text" name="sender_email" id="sender_email" value="" size="42" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image Title:</th>
<td class="WADADataTableCell"><input type="text" name="image_title" id="image_title" value="" size="42" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image:</th>
<td class="WADADataTableCell"><input name="image_name" type="file" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="Submit" class="button" name="Insert" id="Insert" value="Insert" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><span id="Cancel" class="WADATextButton"><a href="photo_Results.php">Cancel</a></span></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
<input name="date" type="hidden" id="date" value="<?php echo date("Y-m-d") ; ?>" />
</div>
</form>
</div>
</div>
</div>
</div>
</body>
<!-- InstanceEnd --></html>
Do you have a url where I can view the problem in context?
mike264653
Test URL
It is in it's rough stages. Most links are not set yet but the db and upload image are in place.
photo_Insert.php
mike264653
I placed an image on the server to see if the coding to display the photo was correct.
I see in the db that you are testing, thank you. here is the entry with the photo added.
photo_Detail.php?photo_id=1
Very odd... Do you have GD2 installed properly on your server? You may want to post a support incident. Does it have troubles if you don't mark it as web images only?
mike264653
Sorry my brain is mush right now, I don't know what you mean by GD2...
As far as the web only option, Yes I tried with and without the option selected as well as not resizing the image. Same results, no upload.
Please post a support incident and somebody will debug this with you. I can't imagine what it could be.
GD is the php library we use to resize images: gd
I thought it might be the reason why the image wasn't created properly. However it shouldn't be used when the option of images only isn't selected, so that would probably rule that out as the cause.
