No File Uploaded: Help please
Thread begun 5/19/2009 4:40 pm by dreamweaver41056 | Last modified 5/27/2009 12:22 pm by dreamweaver41056 | 15149 views | 31 replies |
dreamweaver41056
DW CS4 applied DFP 2.0 upload behavior to WA insert form with a file field. Permissions are correct on image directory.
Uploaded the updated DFP 2.0 directory to the server.
It writes the file name to the db but uploads nothing. No errors in the page or server side (checked error log).
Have checked form for errors and have reapplied behavior several different ways, each time re-uploading the library files
DFP1 always uploaded without problem.
This is very odd. Maybe post a support incident. It thinks that it uploaded the file, so it probably did. Somehow it may be uploading to a different directory than you expect, or the file is getting deleted... I'm really not sure because this is not a known issue, but we are very interested in reproducing the problem and finding out what might be the cause.
You could also try posting the code for the upload here and I can look at it to see if I can spot an issue. There isn't much to go on with your description other than it doesn't work.
dreamweaver41056
insert form code
<form action="products_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Name:</th>
<td class="WADADataTableCell"><input type="text" name="ProdName" id="ProdName" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Short Desc:</th>
<td class="WADADataTableCell"><textarea name="ProdShortDesc" id="ProdShortDesc" cols="32"></textarea></td>
</tr>
<tr>
<th class="WADADataTableHeader">Long Desc:</th>
<td class="WADADataTableCell"><textarea name="ProdLongDesc" id="ProdLongDesc" cols="32"></textarea></td>
</tr>
<tr>
<th class="WADADataTableHeader"> Price:</th>
<td class="WADADataTableCell"><input type="text" name="ProdPrice" id="ProdPrice" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">SKU:</th>
<td class="WADADataTableCell"><input type="text" name="ProdSKU" id="ProdSKU" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Thumb:</th>
<td class="WADADataTableCell"><input type="text" name="ProdThumb" id="ProdThumb" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image:</th>
<td class="WADADataTableCell"><input type="file" name="ProdImage" id="ProdImage" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">ProdCatID:</th>
<select name="ProdCatID" id="ProdCatID">
do {
<option value="<?php echo $row_WADADynListprodcategory['CatID']?>"><?php echo $row_WADADynListprodcategory['CatName']?></option>
} while ($row_WADADynListprodcategory = mysql_fetch_assoc($WADADynListprodcategory));
$rows = mysql_num_rows($WADADynListprodcategory);
if($rows > 0) {
mysql_data_seek($WADADynListprodcategory, 0);
$row_WADADynListprodcategory = mysql_fetch_assoc($WADADynListprodcategory);
</select>
</td>
</tr>
<tr>
<th class="WADADataTableHeader">Weight:</th>
<td class="WADADataTableCell"><input type="text" name="ProdWeight" id="ProdWeight" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Disc Min:</th>
<td class="WADADataTableCell"><input type="text" name="ProdDiscMin" id="ProdDiscMin" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Disc Price:</th>
<td class="WADADataTableCell"><input type="text" name="ProdDiscPrice" id="ProdDiscPrice" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="products_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
fragop363190
Go up in the php code and copy/paste the uploads behavior's Parameters plz.
dreamweaver41056
upload params
// WA_UploadResult1_1 Start
'UploadFolder' => "../prodimages/",
'FileName' => "[FileName]",
'DefaultFileName' => "clear.gif",
'ResizeType' => "2",
'ResizeWidth' => "450",
'ResizeHeight' => "0",
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "ProdImage", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
Please post all of the code above the html in context. That might allow me to spot the problem.
dreamweaver41056
php code
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once('../Connections/handbagsWA.php'); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFile("WA_UploadResult1", "ProdImage", "../prodimages/clear.gif", "../prodpix/", "[FileName]", "2", "[FileName]_[Increment]", "0", "false", "0", "0");
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $handbagsWA;
$WA_table = "products";
$WA_sessionName = "WADA_Insert_products";
$WA_redirectURL = "product_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "ProdID";
$WA_fieldNamesStr = "ProdID|ProdName|ProdShortDesc|ProdLongDesc|ProdPrice|ProdSKU|ProdThumb|ProdImage|ProdWeight|ProdDiscMin|ProdDiscPrice";
$WA_fieldValuesStr = "".((isset($_POST["ProdID"]))?$_POST["ProdID"]:"") ."" . "|" . "".((isset($_POST["ProdName"]))?$_POST["ProdName"]:"") ."" . "|" . "".((isset($_POST["ProdShortDesc"]))?$_POST["ProdShortDesc"]:"") ."" . "|" . "".((isset($_POST["ProdLongDesc"]))?$_POST["ProdLongDesc"]:"") ."" . "|" . "".((isset($_POST["ProdPrice"]))?$_POST["ProdPrice"]:"") ."" . "|" . "".((isset($_POST["ProdSKU"]))?$_POST["ProdSKU"]:"") ."" . "|" . "".((isset($_POST["ProdThumb"]))?$_POST["ProdThumb"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["ProdWeight"]))?$_POST["ProdWeight"]:"") ."" . "|" . "".((isset($_POST["ProdDiscMin"]))?$_POST["ProdDiscMin"]:"") ."" . "|" . "".((isset($_POST["ProdDiscPrice"]))?$_POST["ProdDiscPrice"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL";
$WA_connectionDB = $database_handbagsWA;
if ($WA_redirectURL != "") {
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
dreamweaver41056
Wrong page code: use this instead
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_WADADynListprodcategory = 1000;
$pageNum_WADADynListprodcategory = 0;
if (isset($_GET['pageNum_WADADynListprodcategory'])) {
$pageNum_WADADynListprodcategory = $_GET['pageNum_WADADynListprodcategory'];
$startRow_WADADynListprodcategory = $pageNum_WADADynListprodcategory * $maxRows_WADADynListprodcategory;
mysql_select_db($database_handbagsWA, $handbagsWA);
$query_WADADynListprodcategory = "SELECT CatID, CatName FROM prodcategory ORDER BY CatName";
$query_limit_WADADynListprodcategory = sprintf("%s LIMIT %d, %d", $query_WADADynListprodcategory, $startRow_WADADynListprodcategory, $maxRows_WADADynListprodcategory);
$WADADynListprodcategory = mysql_query($query_limit_WADADynListprodcategory, $handbagsWA) or die(mysql_error());
if (isset($_GET['totalRows_WADADynListprodcategory'])) {
$totalRows_WADADynListprodcategory = $_GET['totalRows_WADADynListprodcategory'];
} else {
$all_WADADynListprodcategory = mysql_query($query_WADADynListprodcategory);
$totalRows_WADADynListprodcategory = mysql_num_rows($all_WADADynListprodcategory);
$totalPages_WADADynListprodcategory = ceil($totalRows_WADADynListprodcategory/$maxRows_WADADynListprodcategory)-1;?>
$WA_redirectURL = "products_Detail.php";
$WA_fieldNamesStr = "ProdName|ProdShortDesc|ProdLongDesc|ProdPrice|ProdSKU|ProdThumb|ProdImage|ProdCatID|ProdWeight|ProdDiscMin|ProdDiscPrice";
$WA_fieldValuesStr = "".((isset($_POST["ProdName"]))?$_POST["ProdName"]:"") ."" . "|" . "".((isset($_POST["ProdShortDesc"]))?$_POST["ProdShortDesc"]:"") ."" . "|" . "".((isset($_POST["ProdLongDesc"]))?$_POST["ProdLongDesc"]:"") ."" . "|" . "".((isset($_POST["ProdPrice"]))?$_POST["ProdPrice"]:"") ."" . "|" . "".((isset($_POST["ProdSKU"]))?$_POST["ProdSKU"]:"") ."" . "|" . "".((isset($_POST["ProdThumb"]))?$_POST["ProdThumb"]:"") ."" . "|" . "".((isset($_POST["ProdImage"]))?$_POST["ProdImage"]:"") ."" . "|" . "".((isset($_POST["ProdCatID"]))?$_POST["ProdCatID"]:"") ."" . "|" . "".((isset($_POST["ProdWeight"]))?$_POST["ProdWeight"]:"") ."" . "|" . "".((isset($_POST["ProdDiscMin"]))?$_POST["ProdDiscMin"]:"") ."" . "|" . "".((isset($_POST["ProdDiscPrice"]))?$_POST["ProdDiscPrice"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL";
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
dreamweaver41056
Please ignore first PHP code post
Please ignore the first PHP code post. That was from a working DFP1 page that I built in CS3.
The second code paste is from the non-functioning DFP2/ CS4 page.
I backed up all of my WA includes for the different iterations as tar files (on the server) so I can flip back and forth.
I am under the gun to complete this project and may need to set up an alternative development site to troubleshoot this issue with DFP2.
Anyway since I can write to the folder using DFP1/CS3 and DW8/MX Kollection proves that this is not a server side issue (not that I ever thought it was).
I still don't see the problem. Please post a support incident and somebody can help you debug this.
