Image slideshows.
Thread begun 5/19/2009 11:00 am by Carl | Last modified 5/23/2009 1:18 pm by CraigR | 2357 views | 1 replies |
Carl
Image slideshows.
Hi
I think it would be good if you created image sideshows, cover flows& gallery's based on javascript (not flash) that makes it easier to implement galleries, sideshows, cover flows and give the user some interaction e.g. apples cover flow on iTunes.
I think that some sort of dynamic function would be good if you could take the name of the image from a database and then show the image and let the user scroll through the images and view larger ones on go to another website from that image.
That would be a very helpful extension as it is tedious to build a gallery and many galleries out there are fiddly to implement and do not work in all browsers.
Just a thought
Carl
CraigRBeta Tester
lightbox 2
what about using lightbox 2. it is javascript and is easy to bind to a recordset.
There is also a modified version which runs a slideshow, by justinbarkuff.
