Authentication System Changed
Thread begun 5/19/2009 2:33 am by fragop363190 | Last modified 5/19/2009 6:38 am by Ray Borduin | 2785 views | 3 replies |
fragop363190
Ok i am not sure what i will say is exactly true but have noticed delay while loading any WebAssist Wizard or Behavior cause of the screen that validates for authenticity of the product.
I got a question, why should this be checked and msg poped up after validation has been made?
After validated once it shouldnt popup again so forms could load faster etc. It is very annoying everytime ot wait 3-5sec for the validation window to open up showing the green mark. Imagine making a project and using behaviors very frequently. The screens will popup 10 times.
Can you guys make a central application in webassist control application for puting Serial Numbers and validating products once or at least when the screen pops up at the 1st time and the user valideates it, the next it shouldnt popup again unless someone formats his computer or uninstalls the product?
Each product should only validate once per DW session. Even though you aren't asked to enter your serial number again it still checks to make sure the one stored is valid.
muddysmurf
I get a sort of little pop up box that tells me what extension I'm trying to use. This is after I've validated. Is there anyway to get rid of that?
This is the portion that slows everything up for me.
It should only pop up once the first time the extension is used. You cannot stop that. If it happens more than once in the same DW session, then I can look into getting it fixed as a bug.
