Editing Menu Contents
Thread begun 3/15/2010 2:34 pm by grgsr | Last modified 3/16/2010 11:01 am by Dani Chankhour | 1468 views | 1 replies |
grgsr
When I try to edit the contents by clicking on the edit menu field from the index page nav area and I go through all the steps and nothing happens.
So I then went to the modify SiteAssist Pro site options and performed the "content" changes e.g adding services rendered and the changes add to the menu. HOWEVER, the whole site changes back to default with all the custom CSS settings vanished........all page content lost.......
I wondered if I need to uninstall SiteAssist Pro then reinstall so I don't have to "modify" the site and just make menu changes icon in the NAV section.
Not sure what I am doing wrong.....any suggestions?
grgsr
Dani Chankhour
Can you explain a little more when you say you say:
"When I try to edit the contents by clicking on the edit menu field from the index page nav area and I go through all the steps and nothing happens."
Are you re-entering the menu writer wizard?
Can you also tell me what version of MW and SAP you have?
You should not have to reinstall SiteAssist Pro and if you reenter the SiteAssist pro wizard then the content in the main content area should not get over written. As far as the styling, you should add your styles to the styles.css, this file does not get overwritten when you reenter the SAP wizard.
