Ribbon + Fullsize Change Size
Thread begun 3/15/2010 8:50 am by tyler815351411 | Last modified 3/15/2010 1:26 pm by Jimmy Wu | 2001 views | 1 replies |
tyler815351411
Hi, I am trying to use the power gallery using the Ribbon + Fullsize.
When I upload the images through the admin section and then view on the live site it has altered the size of the image. This wrecks the look of the site, is it possible to set the image to be a certain size for the fullsize image.
Please can someone help point me in the right direction.
Size Required (Fullsize image) - 534 x 234
Kind Regards
Brian
If you go into the common.css file, you will have to change the .pg-rf .fullsize img css block and add:
height: 234px;
width: 534px;
This will cause all your images to be stretched to fit into that box. If you want the dimensions to stay the same as the original uploaded image, you would want to insert a max-height and max-width instead.
