Problems With New DFP 2.0
Thread begun 5/18/2009 9:31 am by chris98896 | Last modified 5/19/2009 6:43 am by Ray Borduin | 5090 views | 7 replies |
chris98896
Problem # 1 after install with Dreamweaver CS4 DFP will crash Dreamweaver CS4 while tring to activate.
Problem # 2
using Dreamweaver CS3
1 File upload works fine and will update database.
2 update only works if you upload "WILL REMOVE CURRENT INFO IF NO FILE IS UPLOADED".
3 Will Not Put a Default file in if no upload is made.
NO CURRENT HELP FILES FOR 2.0 FOR UPDATING SO I HADE TO GO BY THE 1.x HELP FILES.
fragop363190
The default file feature is not working. I posted a temporary fix here in forums check it out.
We became aware of this issue yesterday. There are a couple of work-arounds for now but we will be working on a free update to address the problem shortly as well. Let us know if you have difficulty implementing one of the proposed work arounds, or post a support incident for help with this directly.
chris98896
Problem Fixed Thank You!
"Try deleting the WinFilecache-########.dat or MacFileCache-########.dat, depending on your operating system, file from the following location:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Also, please make sure that you have the most recent version of our extensions installed.
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders
jonathanfever357012
Default File will not update in database if no upload
i'm having the same issue "Problem # 2" that was posted from "chris98896"
but im using Dreamweaver CS4 ... digital file pro 2 "Will Not Put a Default file in if no upload is made."
what are the workarounds to this issue, i cant seem to find them on the forum?
thank you!
anonymous
Guys, go to this thread here for the workarounds and fixes: showthread.php?t=1060
fragop363190
Oh right forgot to post link to Fix :)
Maybe should make it a new post and just post the fix in it to be easier to find?
If WebAssist allows it ill make a new post named DFP2 temp BUG fixes and post there the fix.
Will be waiting for a WebAssist personell to reply to me before i do it.
We will probably start distributing a fixed file through support in the next couple of days, and we will likely have a dot release to address this issue in a couple of weeks once we can get full QA completed.
Feel free to create a new post with precise directions on a workaround that has worked for you in the meantime.
You can also post a support incident if the instructions are difficult for you to follow and somebody from webassist will be able to help.
