Can't reset mysql root password
Thread begun 3/13/2010 2:21 am by paul386291 | Last modified 3/24/2010 12:17 pm by neilo | 6452 views | 3 replies |
paul386291
Hi there
I'm going crazy trying to reset the mysql root password. I've read plenty of articles on how to do it, but any suggested commands that I enter in terminal don't work.
I can't even access mysql in terminal.
Below are just some of the messages:
Last login: Mon Mar 8 17:34:00 on console
Welcome to Darwin!
paul-dodsons-Computer:~ pauldodson$ /usr/local/mysql/bin/mysql-root
-bash: /usr/local/mysql/bin/mysql-root: No such file or directory
paul-dodsons-Computer:~ pauldodson$ man sharing
No manual entry for sharing
paul-dodsons-Computer:~ pauldodson$ kill `cat /mysql-data-directory/host_name.pid`
cat: /mysql-data-directory/host_name.pid: No such file or directory
kill: usage: kill [-s sigspec | -n signum | -sigspec] [pid | job]... or kill -l [sigspec]
paul-dodsons-Computer:~ pauldodson$ mysqld_safe --init-file=/home/me/mysql-init &
[1] 2422
paul-dodsons-Computer:~ pauldodson$ -bash: mysqld_safe: command not found
mysql
-bash: mysql: command not found
[1]+ Exit 127 mysqld_safe --init-file=/home/me/mysql-init
paul-dodsons-Computer:~ pauldodson$ mysql> UPDATE mysql.user SET Password=PASSWORD('MyNewPass')
-bash: syntax error near unexpected token `('
paul-dodsons-Computer:~ pauldodson$ -> WHERE User='root';
-bash: -: command not found
paul-dodsons-Computer:~ pauldodson$ mysql> FLUSH PRIVILEGES;
Can anyone PLEASE help with this before I go insane.
Thank you.
Paul
neilo
Hi Paul,
'Trying to reset' your mysql root password. Does this mean that you don't have your original password?
Did you set an original password, or was MySql set up without entering a password?
What testing server are you using, i.e. IIS, Wamp, Xampp?
mrobben375515
I am having same problem. I am on WAMP.
neilo
Hiya,
Same question to you, - Did you set a password during the MySql part of the WAMP install? In other words, did you enter one but forget it, or do you have a MySql installation with no password set yet? By default, the WAMP MySql setup doesn't ask you to specify a password!
