Update Cart when Cart form is submitted
Thread begun 5/18/2009 5:51 am by rob148920 | Last modified 5/18/2009 6:02 am by rob148920 | 1615 views | 1 replies |
rob148920
I've done this before ASP, but the same method doesn't seem to work right with PHP.
I need the Cart Display page to update any changes to quantity fields on change.
Currently i'm doing this by using a javascript submit onchange event to each quantity field and i've included a hidden field called "ECartName_Update_1".
This updates the quantity fields fine, however, if i try to delete a item in the cart using the checkbox, the selected item and the last item in the cart are deleted.
If i remove the "ECartName_Update_1" field, the delete function works again, but of course the update onchange event now fails.
What's the correct method?
rob148920
Solved
For some reason there were 2 update events on the page, upon deleting one and changing the field name below, the problem stopped.
I changed the field name to "ECartName_Update_1_x".
