checkout_failure.php all the time for paypal
Thread begun 3/11/2010 12:00 pm by Miguel | Last modified 3/15/2010 6:30 pm by Eric Mittman | 19431 views | 15 replies |
Miguel
Hello im getting this error msg no matter what settings i use, im using ecart4 latest version, i used the wizard filled with a test account that i opened with the paypal sand box also i change the settings to the real account but none work after i add items in the cart and checkout it ask for the info i add my real info and also the test account info i opened in the paypal sandbox both for buyer and seller no matter what i change after i get ask in the confirm page it always send me to the failure page i also have setted the ssl well with godaddy directly they seted the ssl for me just in case it was looking for ssl, but no matter what it keeps failing, what can i do now help please webassist its really urgent!!!.
Transaction Not Completed
We're sorry
Your transaction could not be completed.
Miguel
i have also try this to see what could be the problem
For Direct Payment add these into the checkout_failure.php
PHP Code:
<?php echo(PP_DirectPayment_Result("Full Request")) ?>
<br/><br/>
<?php echo(PP_DirectPayment_Result("Full Response")) ?>
For Express Checkout add these into the pp_checkout_failure.php
PHP Code:
<?php echo $WA_PP_ECO_DoResult->fullRequest; ?>
<br/><br/>
<?php echo $WA_PP_ECO_DoResult->fullResponse; ?>
When you test the checkout after applying this you will get the full request that was sent and the response. In the response you should see all the information about the error message.
and since i added thos lines im getting:
Fatal error: Call to undefined function PP_DirectPayment_Result() in /home/content/xx/xxxxxxx/html/checkout_failure.php on line 107
You should try this again with this set of debug code:
if(!session_id()) session_start();
     echo
"<p>Direct Pay: <br />"
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />"
     echo
"<p>Express Process: <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";   ?>
This relies on the session variables so you will not need to worry about any include files.
Miguel
where do i put that code on wich pages and what spot?
I wanted to update this ticket in case you subscribed to it, I had to edit the debug code that was originally posted. You should use the code that is listed in the post currently.
You will put this code on the page you are getting to in the end, probably the checkout failure page. You can insert this code directly into the code on the page wherever you would like to see it.
Miguel
ok placing it on the failure page i guess not sure where to copy and past the code
Miguel
Thanks for the reply eric this is what im getting:
Direct Pay:
Full Request: <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Header><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents"><Username>lsades_1268001825_biz_api1.yahoo.com</Username><Password>1268001831</Password><Signature>AhOQQx1ueQpbQqqtd5BEElYUmQYIAO5bxYhf7fi.FcVSa2mCaDvyVwwb</Signature><Subject/></Credentials></RequesterCredentials></soap:Header><soap:Body><DoDirectPaymentReq xmlns="urn:ebay:api:PayPalAPI"><DoDirectPaymentRequest><Version xmlns="urn:ebay:apis:eBLBaseComponents">2.20</Version><DoDirectPaymentRequestDetails xmlns="urn:ebay:apis:eBLBaseComponents"><PaymentAction>Sale</PaymentAction><PaymentDetails><OrderTotal currencyID="USD">455.55</OrderTotal><ShippingTotal currencyID="USD">103.7</ShippingTotal><ItemTotal currencyID="USD">300</ItemTotal><TaxTotal currencyID="USD">51.85</TaxTotal><ButtonSource>WebAssist.eCartPHP.Pro.DP</ButtonSource><PaymentDetailsItem><Name>productII</Name><Amount currencyID="USD">100</Amount><Quantity>3</Quantity><Number>20</Number></PaymentDetailsItem><PaymentDetailsItem><Name>productII</Name><Amount currencyID="USD">100</Amount><Quantity>3</Quantity><Number>20</Number></PaymentDetailsItem><ShipToAddress><Name>Test</Name><Street1>1 Main St</Street1><CityName>San Jose</CityName><StateOrProvince>CA</StateOrProvince><PostalCode>95131</PostalCode><Country>US</Country><Phone>408-678-0945</Phone></ShipToAddress></PaymentDetails><CreditCard><CreditCardType>Visa</CreditCardType><CreditCardNumber>4244897774436114</CreditCardNumber><ExpMonth>03</ExpMonth><ExpYear>2015</ExpYear><CardOwner><PayerStatus>verified</PayerStatus><PayerName><FirstName>Test</FirstName><LastName>User</LastName></PayerName><Payer>lsades_1268001737_per@yahoo.com</Payer><PayerCountry>US</PayerCountry><Address><Street1>1 Main St</Street1><CityName>San Jose</CityName><StateOrProvince>CA</StateOrProvince><Country>US</Country><CountryName>US</CountryName><PostalCode>95131</PostalCode><Phone>408-678-0945</Phone></Address></CardOwner><CVV2>069</CVV2></CreditCard><IPAddress>190.37.36.250</IPAddress><MerchantSessionId>jaar4jk5ke1bsupdv4pq1prjc6</MerchantSessionId></DoDirectPaymentRequestDetails></DoDirectPaymentRequest></DoDirectPaymentReq></soap:Body></soap:Envelope>
Full Response: <?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:cc="urn:ebay:apis:CoreComponentTypes" xmlns:ed="urn:ebay:apis:EnhancedDataTypes" xmlns:wsu="http://schemas.xmlsoap.org/ws/2002/07/utility" xmlns:saml="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://schemas.xmlsoap.org/ws/2002/12/secext" xmlns:ebl="urn:ebay:apis:eBLBaseComponents" xmlns:ns="urn:ebay:api:PayPalAPI"><SOAP-ENV:Header><Security xmlns="http://schemas.xmlsoap.org/ws/2002/12/secext" xsi:type="wsse:SecurityType"></Security><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI" xsi:type="ebl:CustomSecurityHeaderType"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:UserIdPasswordType"><Username xsi:type="xs:string"></Username><Password xsi:type="xs:string"></Password><Signature xsi:type="xs:string">AhOQQx1ueQpbQqqtd5BEElYUmQYIAO5bxYhf7fi.FcVSa2mCaDvyVwwb</Signature><Subject xsi:type="xs:string"></Subject></Credentials></RequesterCredentials></SOAP-ENV:Header><SOAP-ENV:Body id="_0"><DoDirectPaymentResponse xmlns="urn:ebay:api:PayPalAPI"><Timestamp xmlns="urn:ebay:apis:eBLBaseComponents">2010-03-11T22:29:49Z</Timestamp><Ack xmlns="urn:ebay:apis:eBLBaseComponents">FailureWithWarning</Ack><CorrelationID xmlns="urn:ebay:apis:eBLBaseComponents">e042409d67003</CorrelationID><Errors xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:ErrorType"><ShortMessage xsi:type="xs:string">Invalid Data</ShortMessage><LongMessage xsi:type="xs:string">This transaction has been completed, but the total of items in the cart did not match the total of all items.</LongMessage><ErrorCode xsi:type="xs:token">15008</ErrorCode><SeverityCode xmlns="urn:ebay:apis:eBLBaseComponents">Warning</SeverityCode></Errors><Errors xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:ErrorType"><ShortMessage xsi:type="xs:string">Invalid Configuration</ShortMessage><LongMessage xsi:type="xs:string">This transaction cannot be processed due to an invalid merchant configuration.</LongMessage><ErrorCode xsi:type="xs:token">10501</ErrorCode><SeverityCode xmlns="urn:ebay:apis:eBLBaseComponents">Error</SeverityCode></Errors><Version xmlns="urn:ebay:apis:eBLBaseComponents">2.20</Version><Build xmlns="urn:ebay:apis:eBLBaseComponents">1224319</Build><Amount xsi:type="cc:BasicAmountType" currencyID="USD">455.55</Amount></DoDirectPaymentResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Express Authorize
Full Request: n/a
Full Response: n/a
Express Process:
Full Request: n/a
Full Response: n/a
Miguel
ok what should i do now? i see it says
For this i dunno what is wrong why would it not match.
and also
i have tested with the sandbox aco**** for testing and also the real one none have worked so far yet dunno what else to change or do.
Miguel
Any tech around yet? really need help on this, sorry to insist so much but kind of really needing your help webassist :)
