Adding multi options per item...
Thread began 3/09/2010 8:21 am by info402047 | Last modified 3/09/2010 5:07 pm by Jason Byrnes | 1019 views | 1 replies |
info402047Beta Tester
When I run the wizard on the ecart to add a product, then tried to add more options to my product, I didn't see away to do it?
For an example, I would like to sell cloth diapers, and they come in 4 sizes, they are different colors, and some are snaps and others are velcro. I want the customer to be able to pick there own options.
How would I go about adding more options?
You can call me: 254-495-4449
Here is the website: softdipes.com
Mark
for each type of option you want to offer, you need to create a new column in your eCart object. Make sure each of those columns has the Unique Attribute set.
Then when adding the add to cart button server behavior, set each of those columns to be up dateable from a select list.
This will add a select list to the page for each column. you can populate the select lists with the options that should be available for option type
