DFP2 Crashes DW
Thread begun 5/16/2009 11:49 am by courtyo | Last modified 5/18/2009 12:30 pm by courtyo | 3392 views | 4 replies |
courtyo
DFP2 Crashes DW
DW crashes every time I try and execute the server behavior.
Happening on both my Mac OSX and Vista machines. Using wiht CS4. I opened a support ticket but hoping there is a quicker solution that someone can post here?
fragop363190
When you say crashes i suppose you have an error code.
I have no clue about MAC machines. But if you give me Vista's error code i might help you. Cause i dont think its a bug but has sth to do either with your DWCS4 installation or with other extensions you got.
anonymous
And... which server behavior are you trying to apply? Upload, delete, etc?
Maybe try clearing your macfilecache.dat file. That seems to be a common problem when updating any extensions with the new extension manager.
courtyo
It was crashing when trying to apply any of the server behaviors. Here's the response from support - which worked - in case anyone else is having trouble:
(Be sure to restart your computer after deleting the file or the changes won't work)
Try deleting the WinFilecache-########.dat or MacFileCache-########.dat, depending on your operating system, file from the following location:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Also, please make sure that you have the most recent version of our extensions installed.
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
