Populate List From Array remains grayed out
Thread begun 5/16/2009 8:06 am by james57944 | Last modified 7/12/2010 8:19 pm by Lee Firth | 3741 views | 4 replies |
james57944
No matter what I try to do, all the selections in the behaviors panel remain grayed out.
I'm pretty good with this stuff and have used/own just about every extension WA makes.
This one has got me pretty frustrated.
I followed the tutorials/examples explicitly.
Please help! Will keep trying.
Jim
PS it's a new Laptop, this is the only WA ext installed. Does it rely on any others??
You need to have the "Create Dyanmic Array" server behavior applied and you need to have a form with two lists on the page. Also you need to have the parent list selected. Are all of those things working correctly?
kgilbert320621
Same problem here
I have tried everything I can think of. Looks like a common problem. If you find a solution can you share it here?
thanks
Usually it is just that you need to have your site defined with a server language and have to apply the Server Behavior "Create Dynamic Array" first.
Lee Firth
Originally Said By: kgilbert320621
I have just had the same problem and it was caused by the fact that the "Create Dynamic Array" code was being written in the "head" tag by the extension. Once I moved the code to before the doctype declaration it worked as expected.
