Template, between BODY TAG?
Thread begun 3/08/2009 5:07 am by Cologne | Last modified 1/15/2010 4:47 pm by Jimmy Wu | 11222 views | 21 replies |
meister281653
Hi there,
I cant insert the Google Maps. I use a DW Template, and the extension always says "Put the Courser inside the BODY TAG" there I am!
How to fix that?
Denis
Danilo Celic
The issue may be in the extension code that tried to recognize where insertion points are within a child page from a template. Can you post a link to your page?
I suppose if you are anxious to get it working you could create a non-template page in the templates directory, add the map there and copy and paste to the correct location on your templated page.
Please post a support incident and include a copy of the page you are working with. This will allow us to reproduce and fix the problem if it has something to do with the way your template is structured.
epiisila369765
I had the same issue, the way I got around it was to put my cursor inside the body tag in code view, then select the promaps insert menu
meister281653
I made it an editable attribute :-)
thanks
denis
CarlE
Example
This is an example of a template page with this issue:
anfahrt_d.php
claude259909
I get the same error and can't get it to work no matter where I put the cursor.
I've tried it on a non-template page and still not working.
Dreamweaver CS3.
You can try detaching it from the template and then trying to insert the map again. Then after inserting the map apply the template again. Or as Ray said above, you can create a non-template page and insert the map there and then copy the necessary code over to the templated page.
claude259909
Originally Said By: Jimmy Wu
If you mean me, I started with a new, non-template page. It will not work on any page. I get the same error.
I start with a new page and click ProMaps. It says to save the page first - I save it. Then, I click on Pro Maps and get the same error.
claude259909
Since the suggestions posted here do not work, what is the procedure to open a support ticket?
