Add another row of thumbnails to the Ribbon + Fullsizw
Thread begun 3/03/2010 9:24 am by chris373619 | Last modified 3/08/2010 9:42 am by Justin Nemeth | 1975 views | 3 replies |
chris373619
Is it possible to add another row of thumbnails right under the first row of thumbnails on the Ribbon + Fullsize lightbox. My gallery has a ton of photos and the 9 or 10 thumbnails seems too little. Another thing, can you ad a slideshow feature? Otherwise, I have no issues with this software. It works great and easy to install.
Justin Nemeth
You can use the Grid + Fullsize gallery which will show all the thumbnails. The ribbon only works with one row since it has the arrows to scroll the ribbon around. Thanks for the slideshow suggestion.
chris373619
I'm trying to customize my grid + full-size gallery using the how to guide. I reduced the number of thumbnails to 8 but how do I make the large thumbnail smaller to reduce the
the width to match the 8 thumbnails. The guide doesn't say how to do that.
Justin Nemeth
Here is a thread with code examples that should help out. You should be able to just change the fullsize image dimensions in the index.php file.
showthread.php?t=10776
