exif iptc extraction with dfp
Thread begun 3/02/2010 5:35 pm by contact318852 | Last modified 3/05/2010 9:26 am by Les Crowley | 6740 views | 9 replies |
contact318852
Just out of curiosity can anyone recommend or point me toward a good tutorial or site that can provide a script that will read keyword from jpgs uploaded through digital file pro?
cheers
anonymous
Can you specify what exactly you want it to do?... meaning are you looking for a script to extract the keyword from EXIF data to, say, store it in a database - or - are you just wanting to view the information from your desktop client?
Regards,
Brian
contact318852
exif
Hi Brian,
Thanks for taking note.
This script would be for a php mysql web application and would read the metadata; specifically keywords, caption, and title from jpgs and populate the database with that information.
i would want it to work with an exisitng upload form, but also be able to process a folder of files uplaoded via ftp.
cheers
anonymous
Let me take a look around and talk to some folks that may have a good answer for this as far as an actual pre-built script.
You will have to do a bit of hand coding, though, to get this to work the way I am thinking.
My thought is you could add to the upload and database action before the redirect occurs where after an image is uploaded, it then gets passed to the script to extract the data and store them into variables - and then you would have to handcode in an additional update query to add the data back into the table.
This can be done - but it will be a complex structure that will probably involve some trial and error.
For stuff that you have FTP'd up, it would be similar where you would create a page (in your admin) to run in the browser after uploading the files. The method here, though, would involve using the PHP scandir command to get the list of all files and then you would need to use a command such as getimagewidth against all the files to determine if they were images. After detemrine if they were images by using a simple "if" statement, you could then pass them through a loop of the extraction script and like before - store the extracted data in variables and add them to the database.
I will see what I can dig up on a script... you may even have to write the script from scratch but I think that is also accomplish-able with PHP commands.
Regards,
Brian
anonymous
Have you had a look at this yet: book.exif.php
I also found this toolkit which was released under the GNU license: index.html
This script also looks like it could do everything you would want and more: exif.php
Best regards,
Brian
contact318852
Thanks Brian,
I did come across those two initial links, but the zenphoto script is something new to me.
Thank you for your pointers on progressing with this. It is a bit above my learning curve - but Ill give it a try.
anonymous
Give it a try on some of the coding... I will be around tonight and tomorrow, so if you get to some hang-ups, post the code and I might be able to help out with some ideas.
Brian
contact318852
Well this is interesting indeed, Im greatful for your suggestion about zenphoto, I installed the entire application, it has ftp upload functions and reads all the metadata, I can use it as my 'admin image backend' - pretty darn cool
anonymous
I'm glad it worked for you. I, too, thought it looked really cool and started messing around with it. I am going to try to write some functions from using some of the code in it and hope to be able to add a few snippets into my Digital File Pro behaviors to give it a little more power.
Regards
Les CrowleyBeta Tester
Hi Brain,
Thanks for the links on EXIF. A while back I wanted to extract the meta data from images and then was sidetracked with another project and never got back to it. Your links put it back in the forefront for me and have given me something useful to work with. Good stuff!
