chart worked in DynamicFlashCharts
had a chart setup in DynamicFlashChart but was difficult to maintain, so upgraded to Dynamic Web Charts and can not seem to get this to work.
the table setup is:
id--------1-------2------an so on
read01---10------21
read02---12------18
read03---15------15
read04---11------19
and so on
I would like a chart to display values from only record 1 showing labels read01, read02, read03. this record would be picked up from the URL ?id=1
with DynamicFlashChart I used static data and values: <?php echo $row_RSmetre['read01']; ?> | <?php echo $row_RSmetre['read02']; ?> and so on
the problem I had any additions I had to reenter the code from scratch as it got changed. I tried this and the wizard would only accept numbers, and the wizard for dynamic data couldn't see how to do this.?
=is read01, read02 different columns or is that the same column with different values?
