version 1
Thread begun 5/14/2009 7:05 pm by p_vouers282571 | Last modified 5/16/2009 7:44 am by fragop363190 | 4733 views | 6 replies |
p_vouers282571
version 1
I really like version 1
What don't you like about version 2. It is just like version 1 except with more features.
p_vouers282571
I think the additional features are great but I don't need any headaches right now. I always look to the forums to see the crashes and problems on a new release.. then wait to buy. What sucks is that the sale will probably be off once the problems are fixed.
fragop363190
If i understood correctly he means that DFP2 isnt working correctly as it should be/intended and DFP1 works but doesnt have new features.
Well i needed the thumbnail/resize feature that is why upgraded but its not working as intended and i can't use it in production currently.
Please describe the exact problem you are having and we can make sure to look into how to resolve it.
fragop363190
Support ticket allready submited and if im correct i'm not the only one submiting it.
Waiting for the updated version of DPF2 that has this issue resolved. Hope very soon.
fragop363190
Can someone plz upload me HelperPHP.php of DFP1 as a Zip attached to this post?
i think i found the problem just want to check it out and compare it with DFP2s helper.
I don't want to say a lot in here cause i might be wrong unless i make it work. If i make it work ill post solution here.
What i can see is different $key parameter on parameters page of insert.php (i applied an upload behavior) about default file and different on code in HelperPHP.php file of DFP2.
Im talking only about the 2nd problem that doesnt use the default image path at all not about the generated code. I can't check about how it is generating code since i never have tried to make an mxp file so i dont know how to check where it generates the code..
As i said the 1st issue, just manually add the filepath + filename to the parameters of DFP2 generated code for default file in the page u used the upload behavior.
But again it wont work as it is not using it in HelperPHP.php and if im correct its a different $key name.
Ill be back with you with a solution as soon as i fix it unless we got a release asap from WebAssist.
