Checkout Form Dynamic Values
Thread begun 5/14/2009 5:06 pm by neo314 | Last modified 5/15/2009 7:17 am by Ray Borduin | 2806 views | 3 replies |
neo314
I just asked a question in the general forum kinda related to this, but in the checkout form wizard, I chose SEVER_NAME from the bindings tab and it put this code on the page. Thought it might be a bug.
if ("<?php echo((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:"") ?>" != "") {
header("Location: ". "<?php echo((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:"") ?>"); exit;
Not sure why you would choose server name... it isn't a bug, but it doesn't make much sense to do.
neo314
Because the local testing server is different from the online developments server is different from the live server.
This relates to an earlier question. I input that server value temporarily until I caould rewrite the code to be "http://".$_SERVER['SERVER_NAME']."/destination.php"
Perhaps you answer in the other forum will help with entering that value in the GUI without generating an error from WA extension interfaces. :D
I see. Well it appears this is a bug or missing feature and our interface doesn't allow you to have code in the redirect field.
Instead of using:
try using:
" .((isset($_SERVER["SERVER_NAME"]))?$_SERVER["SERVER_NAME"]:""). "
In general, only fields with lighning bolts will support dynamic values. I will log this as a feature request to accept dynamic values in the redirect fields of the checkout wizard in the next version.
