Javascript error at ThemeIt launch
Thread begun 2/22/2010 6:48 pm by swrmick260574 | Last modified 3/09/2010 8:04 pm by iggymak198560 | 8386 views | 25 replies |
swrmick260574
Hello,
I am having problems getting ThemeIt to run.
I have installed and activated it.
With a new html page consisting of one coloured word and cursor focus within the page design view, I use the main menu to open ThemeIt. (Insert => Webassist => ThemeIt)
The themeIt interface opens, but with nothing in the left panel.
At this moment a javascript alert appears with the text;
"While executing onLoad in wa_managetheme.htm a JavaScript error occurred." (see attachment 1.jpg)
When the "OK" button is clicked, an identical JavaScript alert appears.
When "OK" is clicked the second alert disappears and the themeIt interface remains, but with nothing in the left panel.
If either left panel tab ("Manage Colors", "Manage Images"), or the "Preview" tab in the right panel is clicked a new JavaScript alert appears, with the text;
"While executing onMouseUp in wa_managetheme.htm a JavaScript error occurred."
The Color Importer appears to be working correctly. It will display either a local html page or the webassist.com homepage.
When the ThemeIt window is closed, a JavaScript alert appears with the text;
"While executing timer in wa_themeit.htm the following error(s) occurred.
at line 127 of the file C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS3\configuration\Floaters\wa_themeit.js: TypeError: MM.updatedImages[image].imageProps has no properties." (see attachment 2.jpg)
On inspection the file wa_themeit.js does not exist in that location. (see attachment 3.jpg)
System:
Vista 64 bit
Dreamweaver CS3
Most webassist extensions installed, plus 4 or 5 non webassist extensions.
swrmick260574
Additional Information
To troubleshoot the problems I have;
Re-downloaded the extension. the file sizes were identical. (5.15 MB (5,407,530 bytes))
Disabled/Re-enabled the extension numerous times.
Uninstalled/Reinstalled the extension numerous times.
Deleted winFileCache.dat numerous times and allowed dreamweaver to recreate it by Starting then Closing Dreamweaver.
Restarted the PC numerous times during troubleshooting process.
82rocktoy128440
same problem
I am having the same problem!
p.woodall208922
Totally predicable error prone launch of new product
Me to!
Another example of WebAssist producing a defective product.
Web Assist have you not heard about PRODUCT TESTING BEFORE you take our money.
Doris371530
Problem
I have one error coming up, which stops the programm. Spend all morning with it. Does not work!
We have been working with users through our support incident system and have identified and fixed several bugs causing issues.
We do product testing and even have a small beta group that helps, but everyone's site, page, css, and system is unique, so unfortunately the day after a large release when it gets into hundreds of people's hands we sometimes run into errors.
We are working hard to address those errors now and will be creating a dot release in the next couple of days to address any issues we find.
If anyone would like immediate assistance, email me at ray@webassist.com and include your phone number and I will personally call and debug the issue with you until it is resolved.
swrmick260574
Not solved yet.
Installing Theme-It 1.0.1 Build 019 (Beta) does not change any of the symptoms I described here in my system.
I have opened a support incident so that we can work with you directly to get this issue resolved.
Please update your support incident with a phone number where we can contact you and we will get in touch with you as soon as possible to debug this issue.
Thank you for your patience.
ernietamminga142573
Theme-It just installed; doesn't work
I too am getting the JavaScript error when trying to use Theme-It.
I already tried the usual route of deleting the Win Cache file. Doesn't change anything.
"At line 411... wa_themeit.js;dims has no properties.
I'm using Dreamweaver CS4.
VERY frustrating.
82rocktoy128440
broken
I too Installed Theme-It 1.0.1 Build 019 (Beta) and when I start DW I get an error message and when I try to run Theme It nothing happens, don't open!
"unable to find file wa_themeit.html in the configuration/floaters directory"
