adding a validated field
Thread began 2/21/2010 3:49 pm by jspoerer286380 | Last modified 3/15/2010 1:56 pm by Dani Chankhour | 3977 views | 13 replies |
jspoerer286380
Hi everybody... I just bought the Contact Form Solution Pack and I´m dissapointed !!
The first thing I wanted to do is to add a new field to the form but validated the same way they are in the original form and it seems is not possible if you don´t have the CSS Form builder !! I don´t remember that they warned the clients with this issue... If I knew this before i wouldn´t buy the Solution Pack.
Does anybody now if it is possible to add a validated field without having to buy another product ???
Thank You in advance,
Jorge Spoerer
CHILE
Dani Chankhour
Yes. You could add spry validation to your new field. In Dreamweaver open the Insert Menu (Window -> Insert), click on the text field, and then select spry from the insert menu, and select Spry Validation Text field.
Note: Although this is not a common case, but this is a client side validation, so if the user have Javascript disabled on their browsers then the validation won't work.
Let me know if you have any other questions.
jspoerer286380
reply
Thanks for your help Dani.... but I did exactly that !! (before sending my post). That gave me some client validation you are right...
But I was meaning server side validation as well... as the other fields of the form... is that possible ??
BR,
Jorge
Dani Chankhour
Yes. This will require a few steps.
1. First you need to make a copy of a line 14, which is a validation for the name field and past it under line 20. And then you will need to update two things: the form element name, and the last parameter value from 1 to 7.
2. Then start by copying line 68 to 77 and pasting that under the form field you have added. Again make sure to replace the name with your form field name. If you have already applied spry validation, then you probably just need to surround the spry with line 68-72 and line 74-77.
Basically, if you use one of the already existed form elements as a starting point, and just change the form element name in the validation and add the extra line of code at the top of the page, you should be able to add server side validation to your new form element.
jspoerer286380
validation issue
Thank You Dani... I will try it...
One doubt... what are those 2 input fields called "addblock" & "secondblock" the form has ??
BR,
Jorge
Those are honeypot fields. They are placed there to try to fool bots into filling them out to prevent non-human browsers from validating.
Honeypot fields are invisible fields on the form. Invisible is different than hidden. Hidden is a type of field that is not displayed for editing. Bots understand hidden fields, because hidden fields often carry identifying information that has to be returned intact. Invisible fields are ordinary editable fields that have been made invisible in the browser.
The invisibility of the honeypot fields is a key way that bots reveal themselves. Because bots do not process the entirety of the HTML, CSS, and Javascript in the form, and because they do not build a visual representation of the page, and because they do not perceive the form as people do, they cannot distinguish invisible fields from visible ones. They will put data into honeypot fields because they don't know any better.
jspoerer286380
example request...
Hi Dani... it´s me again
The form is not working for me... I don´t know if I can ask you to send me a copy of the contactus.php file but with 2 additional validated fields. One the same as the "Contact_Name" and other validating numbers since i would like to use it for a phone number...
That´s all I need please,
Thank You,
Jorge
Dani Chankhour
I can't really assist you with that, but if you send me your contact page (only the contact page), i will try to debug the issue on my end and tell you what you need to change exactly.
jspoerer286380
file
Ok Dani, here goes the file... Is the original contactus.php of the contact form package without one security question but with 2 new fields.. one for the family name and other for a telephone number.
BR,
Jorge
contactus.zip
Dani Chankhour
Ok, so you will just need to add these two lines of code under line 19 of your page:
$WAFV_Errors .= WAValidateRQ(((isset($_POST["apellido"]))?$_POST["apellido"]:"") . "",true,8);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["telefono"]))?$_POST["telefono"]:"") . "",true,9);
And then on line 87 change the "1" to an "8" and on line 103 change the "1" to a "9".
this will give you fields server side validation, you will just need to update the text that is shown for the validation.
