menu images not showing
Thread begun 5/13/2009 8:31 am by UK Web Design | Last modified 5/14/2009 10:43 am by UK Web Design | 4439 views | 6 replies |
UK Web Design
used css menu writer 1 yesterday worked perfectly today on a different menu on a different site the right or center images will not show up, well not even got to the publishing stage yet.
what is happening?
any advice?
Regards
Dave
Post a url where you are having problems. It is too difficult to debug what might be the problem without looking at the output. Perhaps the images weren't properly saved or copied to the correct location.
UK Web Design
Hi Ray thanks for the speedy reply the url is worldwebsolutions.net/
have looked in the file structure and all images are saved to the correct folders and the css all appears to point to the corresponding folders
Is this Menu writer V1? It may be fixed if you use V2, but I'm not sure. Does it work if you add one menu to a blank page?
UK Web Design
yes it is v1 and no it doesnt work on blank page
It would be interesting to try it in v2 and see if it works. Maybe export your menu and send it in an incident to WebAssist support. They could then try it in both v1 and v2 to see if it works in v2 or if they can find a fix for v1.
V2 uses a slightly different menu structure, which may fix this problem but I couldn't be sure without testing. I can't seem to get it working on your page by manipulating the css alone, but that doesn't mean I didn't miss anything.
UK Web Design
ok thanks Ray i will export it tomorrow and fill out a support ticket thanks for your speedy replies.
