Map fails to display
Thread begun 5/13/2009 6:42 am by awatson4180830 | Last modified 6/03/2009 4:20 pm by Ray Borduin | 4418 views | 5 replies |
awatson4180830
I have just installed the latest version of Pro Maps Ver 1.0.4 having previously removed the 1.0.2. to get the address markers to display on IE6 (Webassist's recommendation). Now the map will not display. The API key is the same as before, but when viewing the pages locally, still no map. Can anyone assist me? I have not uploaded the new pages to the server yet, in case there is going to be a problem.
You would have to upload the pages to a location where we could look at them to debug this issue. Without looking at the page it would be nearly impossible to debug.
bgillan354107
ProMaps - no local preview in DW CS3
I'm jumping in with the same (or similar) problem when trying to preview the maps locally with DW CS3. The maps work fine when uploaded to the server, but in version 1.04 I can't see them locally. You can (hopefully) see an example at:
contact_us.htm. It would be great to find a work-around for this. It's a pain to have to upload before you know if you've got what you want with the settings.
BillG
You would have to update your api key each time. Probably the best bet is to keep uploading it.
randy213685
How was this resolved?
I have the same problem. The API seems to be holding up the display. What happened with this issue?
What exactly is the problem? Is there a url where we can view it to help you debug the cause?
