DA update record
Thread begun 5/12/2009 12:21 pm by mustang_sally_85344510 | Last modified 5/13/2009 3:57 pm by Ray Borduin | 4329 views | 6 replies |
DA update record
Was wondering..
When using DA update single record from the server behaviors panel....
I get this result in the form field:
{rsupdate.fieldName}
But when I use DataAssist wizard I get:
<?php echo (str_replace(.....
It just uses a slightly different syntax. One DW recognizes and replaces with {rsupdate.fieldName} and the other it does not recognize so it puts the raw code. The raw code is actually similar just the second example adds the str_replace function to account for double quotes in the database values.
So, should we all be replacing the raw code with str_replace function? Or will it still work properly in raw code?
It should all work fine. If you have any problems with double quotes then you can add the str_replace function manually.
Your too good to me :)
Thank you for all of your help!!!
So,...
how much of the str_replace code do I have to use? I notice in the other wizard it gives a str_replace with WAAKT ....do I have to use this also?
It is only needed when you have single quotes in your value and you are trying to display that value in a form element.
