Big Problem - not able to select some of the images
Thread begun 2/11/2010 2:36 pm by rick262661 | Last modified 2/12/2010 12:42 pm by Justin Nemeth | 3946 views | 4 replies |
rick262661
In admin area in Manage Images, I have 21 images, and out of those I can not select 3 to edit. When I click on them the information from my previous selection shows.
In in Mac OSX 10, FireFox 3.5.
Rick
rick262661
There must be some sort of coding problem on the "Single Image Upload" "Description" input area.
If I just upload the image without filling in the Description, and then going to Managing Images and filling the description, it works.
But I had to go into the Database to delete the existing images, because I could not select them in the manage Images area.
So at this point I'm telling my client to add the description in after uploading the images.
Hope Webassist can find a fix for this bug.
Justin Nemeth
Can you paste the exact description you were using on the single image upload form? That will help us track down the issue. That is a good workaround you found for now though.
-justin
rick262661
I don't have exact text I used, I had to go into the database and delete the iamge as I was not able to select it in Manage Images.
But it is something like this:
<span style="float:right; text-align:right;">Greeting Cards $1 <a href="https://www.paypal.com/cgi-bin/webscr?cmd=_xclick&business=creatinghappy@aol.com&item_name=Stardust & Moonbeams - Greeting Card&item_number=0003GC&amount=1.00&currency_code=USD&undefined_quantity=1&no_shipping=1" title="Make payments with PayPal - it's fast, free and secure!" target="_blank">Buy</a>
Matted Prints $4 <a href="https://www.paypal.com/cgi-bin/webscr?cmd=_xclick&business=creatinghappy@aol.com&item_name=Stardust & Moonbeams - Matted Print&item_number=0003P&amount=4.00&currency_code=USD&undefined_quantity=1&no_shipping=1" title="Make payments with PayPal - it's fast, free and secure!" target="_blank">Buy</a></span><div style="clear:both;"></div>
The post below shows the PayPal problem I was having, and the code you gave for the fix.
showthread.php?t=9752
One note: the image was not selectable in Manage images, it did show up in the front-end.
I went to the database and deleted the description information, hoping that would fix the problem, but it did not, the image was still not selectable in Managing Images.
Rick
Justin Nemeth
Rick, trying editing the admin/common/imageinfo.php file. Replace line 27 with this:
$info[] = '"' . $col . '":"' . str_replace('"', '\"', str_replace("\n", '\n', str_replace("\r", '', $val))) . '"';
That seemed to fix the issues when I tested using your description line above.
-justin
