Help with Condition Validation...
Thread begun 2/09/2010 10:56 am by Gareth.TannattNash253613 | Last modified 2/23/2010 7:44 pm by Dani Chankhour | 6063 views | 15 replies |
Hi Guys,
I'm new to WA Validation and a little lost, I have a simple form - (Update Form)
With
<select name="accounttype"> m/a
<input type="text" id="dmxCalendar_1> Date input
<input type="text" id="dmxCalendar_2> Date Input
<input name="FreeTrial" type="checkbox" id="FreeTrial" value="Y" />
The basis is that the following form elements should be enables and validated if accounttype = m or disabled and not validated if account type = a
Enabled if accounttype = m
dmxCalendar_1
dmxCalendar_2
FreeTrial
Validated - Required if accounttype = m
dmxCalendar_1
dmxCalendar_2
Disabled and no validation if accounttype = a
dmxCalendar_1
dmxCalendar_2
FreeTrial
Hope that makes sense.....
Now I've got to a certain point where I have applied the validations, but can't see how to apply them to the select item as a variable... but not sure how to do it.........
my code is below...
function WAtrimIt(theString,leaveLeft,leaveRight) {
if (!leaveLeft) {
while (theString.charAt(0) == " ")
theString = theString.substring(1);
if (!leaveRight) {
while (theString.charAt(theString.length-1) == " ")
theString = theString.substring(0,theString.length-1);
return theString;
function WAFV_GetValueFromInputType(formElement,inputType,trimWhite) {
var value="";
if (inputType == "select") {
if (formElement.selectedIndex != -1 && formElement.options[formElement.selectedIndex].value && formElement.options[formElement.selectedIndex].value != "") {
value = formElement.options[formElement.selectedIndex].value;
else if (inputType == "checkbox") {
if (formElement.length) {
for (var x=0; x<formElement.length ; x++) {
if (formElement[x].checked && formElement[x].value!="") {
value = formElement[x].value;
break;
else if (formElement.checked)
value = formElement.value;
else if (inputType == "radio") {
for (var x=0; x<formElement.length; x++) {
break;
else if (inputType == "radiogroup") {
break;
else if (inputType == "iRite") {
var theEditor = FCKeditorAPI.GetInstance(formElement.name) ;
value = theEditor.GetXHTML(true);
else {
var value = formElement.value;
value=value.replace(/<p>(\&\#160\;)*<\/p>/,"");
if (trimWhite) {
value = WAtrimIt(value);
return value;
function WAAddError(formElement,errorMsg,focusIt,stopIt) {
if (document.WAFV_Error) {
document.WAFV_Error += "\n" + errorMsg;
else {
document.WAFV_Error = errorMsg;
if (!document.WAFV_InvalidArray) {
document.WAFV_InvalidArray = new Array();
document.WAFV_InvalidArray[document.WAFV_InvalidArray.length] = formElement;
if (focusIt && !document.WAFV_Focus) {
document.WAFV_Focus = focusIt;
if (stopIt == 1) {
document.WAFV_Stop = true;
else if (stopIt == 2) {
formElement.WAFV_Continue = true;
else if (stopIt == 3) {
formElement.WAFV_Stop = true;
formElement.WAFV_Continue = false;
function WAValidateRQ(formElement,errorMsg,focusIt,stopIt,trimWhite,inputType) {
var isValid = true;
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
if (!document.WAFV_Stop && !formElement.WAFV_Stop) {
var value=WAFV_GetValueFromInputType(formElement,inputType,trimWhite);
if (value == "") {
isValid = false;
if (!isValid) {
WAAddError(formElement,errorMsg,focusIt,stopIt);
function WAAlertErrors(errorHead,errorFoot,setFocus,submitForm,allowOverride) {
if (!document.WAFV_StopAlert) {
document.WAFV_StopAlert = true;
if (document.WAFV_InvalidArray) {
var errorMsg = document.WAFV_Error;
if (errorHead!="")
errorMsg = errorHead + "\n" + errorMsg;
if (errorFoot!="")
errorMsg += "\n" + errorFoot;
document.MM_returnValue = false;
if (document.WAFV_Error!="") {
if (allowOverride) {
if (confirm(errorMsg.replace(/&quot;/g,'"'))) {
document.MM_returnValue = true;
return;
else {
alert(errorMsg.replace(/&quot;/g,'"'));
else if (submitForm)
submitForm.submit();
if (setFocus && document.WAFV_Focus) {
if (document.getElementById(document.WAFV_Focus.name+"___Config") && document.WAFV_Focus.type.toLowerCase() == "hidden") {
var theEditor = FCKeditorAPI.GetInstance(document.WAFV_Focus.name);
theEditor.EditorWindow.focus();
setTimeout("setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
document.tempFocus = document.WAFV_Focus;
setTimeout("document.tempFocus.focus();setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
for (var x=0; x<document.WAFV_InvalidArray.length; x++) {
document.WAFV_InvalidArray[x].WAFV_Stop = false;
else {
if (submitForm) {
document.WAFV_Focus = false;
document.WAFV_Error = false;
document.WAFV_InvalidArray = false;
function WAValidateCD(triggerElement,targetElement,enable) {
var isValid = true;
var invalidArray = document.WAFV_InvalidArray;
if (invalidArray) {
if (triggerElement == document)
isValid = false;
else {
for (var x=0; x<invalidArray.length && isValid; x++) {
if (invalidArray[x]==triggerElement) {
isValid = false;
if (!isValid) {
enable = !enable;
if (targetElement.length) targetElement=targetElement[0];
if (enable) {
targetElement.WAFV_Stop = false;
else {
targetElement.WAFV_Stop = true;
function iRiteState(editorInstance,enable) {
if (!enable) {
if (document.all) {
editorInstance.EditorDocument.body.disabled = true;
else {
editorInstance.EditorDocument.designMode = "off";
editorInstance.EditorWindow.parent.FCK.ToolbarSet.Disable();
document.buttonRefreshStateClone = editorInstance.EditorWindow.parent.FCKToolbarButton.prototype.RefreshState;
document.specialComboRefreshStateClone = editorInstance.EditorWindow.parent.FCKToolbarSpecialCombo.prototype.RefreshState;
editorInstance.EditorWindow.parent.FCKToolbarButton.prototype.RefreshState = function(){return false;};
editorInstance.EditorWindow.parent.FCKToolbarSpecialCombo.prototype.RefreshState = function(){return false;};
else {
if (document.all) {
editorInstance.EditorDocument.body.disabled = false;
else {
editorInstance.EditorDocument.designMode = "on";
editorInstance.EditorWindow.parent.FCK.ToolbarSet.Enable();
if (document.buttonRefreshStateClone) {
editorInstance.EditorWindow.parent.FCKToolbarButton.prototype.RefreshState = document.buttonRefreshStateClone;
editorInstance.EditorWindow.parent.FCKToolbarSpecialCombo.prototype.RefreshState = document.specialComboRefreshStateClone;
editorInstance.EditorWindow.parent.FCK.ToolbarSet.RefreshModeState();
function WAValidateEN(triggerElement,targetElement,enable) {
var isValid = true;
if (invalidArray) {
isValid = false;
else {
isValid = false;
invalidArray[x].WAFV_Stop = false;
if (!isValid) {
enable = !enable;
if (enable) {
if (document.getElementById(targetElement.name+"___Config") && targetElement.type.toLowerCase() == "hidden") {
var theEditor = FCKeditorAPI.GetInstance(targetElement.name);
iRiteState(theEditor,true);
else {
targetElement.disabled = "";
else {
iRiteState(theEditor,false);
else {
targetElement.disabled = "disabled";
targetElement.disabled = "true";
</script>
and the form is -
<form action="" method="post" name="updateaccount" id="updateaccount" onsubmit="WAValidateRQ(document.forms[0].dmxCalendar_1,'Start Date is required',document.forms[0].dmxCalendar_1,0,false,'text');WAValidateRQ(document.forms[0].dmxCalendar_2,'End Date is required',document.forms[0].dmxCalendar_2,0,false,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false,false);return document.MM_returnValue">
<fieldset>
<h3>Account Detail</h3>
<ul>
<li>
<label>Account Type <span class="redx">*</span>: </label>
<select name="accounttype" id="accounttype" onchange="WAValidateCD(document.forms[0].accounttype,document.forms[0].dmxCalendar_1,false);WAValidateEN(document.forms[0].accounttype,document.forms[0].dmxCalendar_1,false);WAValidateCD(document.forms[0].accounttype,document.forms[0].dmxCalendar_2,false);WAValidateEN(document.forms[0].accounttype,document.forms[0].dmxCalendar_2,false);WAValidateEN(document.forms[0].accounttype,document.forms[0].FreeTrial,false)">
<option value="m" <%If (Not isNull((CompanyDetail.Fields.Item("JBCLAccountType").Value))) Then If ("m" = CStr((CompanyDetail.Fields.Item("JBCLAccountType").Value))) Then Response.Write("selected=""selected""") : Response.Write("")%>>Fixed Term Contract</option>
<option value="a" <%If (Not isNull((CompanyDetail.Fields.Item("JBCLAccountType").Value))) Then If ("a" = CStr((CompanyDetail.Fields.Item("JBCLAccountType").Value))) Then Response.Write("selected=""selected""") : Response.Write("")%>>Pay as You Go</option>
</select>
</li>
<li>
<label>Start Date <span class="redx">*</span>: </label>
<input type="text" id="dmxCalendar_1" name="dmxCalendar_1" readonly="readonly" />
// <![CDATA[
$(function() {$('#dmxCalendar_1').datepicker({
skin : "dmxCalendar",
dateFormat : "M d, yy",
showStatus : true,
numberOfMonths : [1,1],
showAnim : "fadeIn",
showOptions :
easing : "easeOutBounce",
direction : "up"
duration : "normal",
showOn : "both",
buttonImage : "../Styles/dmxCalendar/calendar_icon.gif",
buttonImageOnly : true,
prompt : ""
</script>
</li><li>
<label>End Date <span class="redx">*</span>: </label>
<input type="text" id="dmxCalendar_2" name="dmxCalendar_2" readonly="readonly" />
// <![CDATA[
$(function() {$('#dmxCalendar_2').datepicker({
showStatus : true,
showOptions :
direction : "up"
showOn : "both",
prompt : ""
</script>
</li><li>
<label>Free Trial: </label>
</li>
<li>
<label></label>
<input type="submit" name="update" id="update" value="UPDATE" />
</li>
</ul>
</fieldset>
</form>
You would want to put conditional statements around the conditional validations to check the account type in the onsubmit section of the form, not in the onchange of the select list.
Please could you provide an example?
Thank you
It looks like you moved these validations to the onchange of the select box:
You would want to undo that change. Then you would want to put in if statements similar to this:
if(<account type> == "m") WAValidateCD(document.forms[0].accounttype,document.forms[0].dmxCalendar_1,false);
Hi Jimmy,
I presume you mean change the code associated with the onchange event of the select item? - Sorry Mate not much good at Javascript - but this is what I have put, which doesn't work at all...
<fieldset>
<ul>
<li>
<select name="accounttype" id="accounttype" onchange=if(<account type> == "m") WAValidateCD(document.forms[0].accounttype,document.forms[0].dmxCalendar_1,false) ">
</select>
</li>
<li>
Appreciate your help.
Thank you
I was just giving you some pseudocode so that you could implement it yourself.
Just so I know how to better guide you, what changes have you made to the form and the validation since you created it?
Did you move some function calls to the onchange of the select?
At the moment, I just have the Form doing the following -
<form action="" method="post" name="updateaccount" id="updateaccount" onsubmit="WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false,false);return document.MM_returnValue">
But still have the select item reading like so -
</select>
All of which are OnChange -
Is this incorrect?
Appreciate any help you can give, as this really isn't my area of expertise - thanks
Anyone out there?
Dani Chankhour
the check that you need to have for the validation should be something like this:
if(document.getElementById('accounttype').options[document.getElementById('accounttype').selectedIndex].value == "a")
or
if(document.getElementById('accounttype').options[document.getElementById('accounttype').selectedIndex].value == "m")
You could use that to check which validation to use.
I was not able to test this with your page. But if you post your file and any related sub folders (in a zip file), i can try to see where you exactly you need to place that code.
