can't startup CSS Menu Writer
Thread begun 3/11/2010 12:01 pm by taro_bmonk403028 | Last modified 3/12/2010 2:04 pm by Jimmy Wu | 2780 views | 3 replies |
taro_bmonk403028
I just bought and installed CSS Menu Writer and I can't get it to work at all. go to Insert > WebAssist > CSS Menu Writer and this error shows:
'While executing onLoad in wamw_serial.htm, the following JavaScript error(s) occurred: At line 214 of file "Macintosh HD:Applications:Adobe Dreamweaver CS4:Configuration:Shared:WebAssist:CSSMenuWriter:Library:Shared_Ser_Mactivation.js": document.formLayer.document has no properties'
I've already viewed this thread: showthread.php?t=10853 and followed all the instructions. Even removed CSS Menu Writer, dumped the Configurations folder, restarted the computer, Zapped PRam, and reinstalled the extension, then dumped the .dat file and started Dreamweaver again and still, the same error.
I'm running Dreamweaver 10.0 and Adobe Extension Manager CS4 v2.0.274 on Snow Leopard 10.6.2
Please help!
The line referred to in that error is in regards to you not being able to connect to our activation server to activate the product. If you have any security, virus scan or firewall software running, try to disable these before trying to activate and see if you get the same error. If you do, please post back.
taro_bmonk403028
thank you!
I scaled down my security settings and it worked! Many thanks. And it seems to be a pretty great program so far!
