Error Changing theme
Thread begun 10/04/2010 9:58 am by Daryl | Last modified 5/31/2012 11:25 am by Jason Byrnes | 7573 views | 12 replies |
DarylBeta Tester
When I change a theme colour or upload a logo I get a 500 error.
The URL that seems to be failing is
mywebsite.com/webassist/plugins/styler/unload.php
There isnt a directory called webassist in my download of PS4
Any ideas?
That folder gets created by the installer. It actually gets moved from Installer/webassist.
The purpose of installing that folder is to get around folder permisions issues, but it seems to backfire in some cases. My guess is that you have to change the folder permissions from '777' to '755'. This has worked for several users that reported a similar problem.
DarylBeta Tester
Do I need to reinstall but change the folder permissions first?
No, you should be able to use the ISP admin to update the permissions now that the files are installed and should not have to reinstall.
oxnardjose1372442
Error loading theme
I've uploaded the files with full rights but still having the same problem when trying to change anything within the theme or design area of Powerstore 4. Hopefully you guys can can fix this problem because I really like Webassist team. Please find the issue!!
I think it is your ISP that has set up a condition to not run .php pages that are set up with full permissions. I think the problem was the full permissions we set up on the files in the first place. Full permissions might be the problem and not the solution. Like I said, at least one user reported changing from full permissions "777" to permissions "755" fixed it for them.
We can have someone call you, but it is likely that we will have to ask your ISP what permissions will work to allow .php files to run from that directory.
oxnardjose1372442
I will try tonight to make that change and I will post back if it does in fact work, Thank you.
oxnardjose1372442
This did not work for me!! I had full permissions and nothing!
I can change the design if I create a new one but I cannot eit the design everything is super slow and sometimes it doesn't want to cancel or save
I'll open a support ticket so that we can have an engineer call you and look into this with you directly. Please update your support incident from the mywebassit section of our main site and include contact information so that someone can call an review this issue with you.
DarylBeta Tester
Which files and folders need changing to 755? all that are 777?
