Input Date in Euro Format
Thread begun 8/28/2009 4:28 am by kirk319254 | Last modified 2/04/2010 4:05 pm by Jason Byrnes | 8847 views | 7 replies |
kirk319254
Good afternoon,
I have been searching in how to input the date into mysql in a Euro format (dd/mm/yyyy. I appreciate that mysql uses (yyyy/mm/dd). I do not mind it being in this format in the database but would like to make it more user friendly when inputing the dates.
I own Admin Suite (Site Assist -Data Assist-Security Assist-Cookies Toolkit- Digital File Pro) Is there any way I could use any of these products to accomplish this easy. ( I know as a back up plan I could validate the fields with ajax in Dreamweaver and force them to input in the Mysql format yyyy/mm/dd)
I am very new to this and use Dreamweaver to do all the work behind the scenes which means my knowledge of PHP is limited so any guidance or advice will be appreciated.
Thank you,
Kirk
When dealing with dates in MySQL With PHP, I like to store the date as the PHP Time stamp in an Integer column. The php time stamp is the number of seconds from January 1, 1970 to the date entered.
On the insert, you can use the PHP strtotime() function to convert the date that is entered to the php time stamp.
In DataAssist, when you bind a column to a form element, you get code like:
<?php echo ((isset($_POST["dateElement"]))?$_POST["dateElement"]:""); ?>
change this to:
<?php echo ((isset($_POST["dateElement"]))?strtotime($_POST["dateElement"]):""); ?>
to convert the entered date to a php time stamp. so if the enter:
2/2/2009
The value stored in the database is:
1233561600
when you pull the information out of the database, you can convert it from the time stamp to the date using the date function. for example:
<?php echo date("d/m/Y"$row_RecordsetName['DateColumn']); ?>
will convert the time stamp to the DD/MM/YYYY format.
more information on the strtotime() and date() functions can be found here:
strtotime
function.date.php
kirk319254
Date Input Euro Style
Hi Jason,
Sorry for the delays in replying but things have been hectic (not good hectic)
I appreciate the time stamp advice but the only concern I have which I did not mention in the first post is that I am trying to set up a database for our small library and thought it would at a later stage be able to be put on the net.
The only thing is that we have some books dating back hundreds of years with one even being in the 1600's so am not sure if the time stamp will work.
But being a newbie in I could be wrong.
Any ideas gratefully received.
Thank you,
Kirk
No the time stamp wont work in this instance.
On the form where the users enter the information use Validation Toolkit to apply Client side validation.
Use Date time client side validation to validate the entered date.
Set ti to allow mm/dd/yyyy to be entered.
And set the reformat option to yyyy/mm/dd. This will convert the entered date to the MySQL Format when the form is submitted.
jw291405
Hi Jason,
Does the validation solution you suggest mean that the integer date column is no longer necessary?
Yes, that's correct. You would use a standard date column.
dlovas275157
Jason/Kirk,
I have followed the instructions in this thread, and the "timestamp" version discussed works great. However, I cannot get the "date" version working. I need the "date" version for date prior to 1970. (euro not needed, just a basic date version). My mysql database column is formatted as "date" 0000-00-00.
Could you please let me know if you ever got this working, and what I am possible doing wrong.
Steps I took:
1. Generated insert form with DataAssist
2. Added datepicker to date field using CSS Form Builder
3. Re-Binded Insert SB to new CSS Form Recordset values
4. Applied client side validation on date field (allow mm/dd/yyyy) and reformat to (yyyy/mm/dd) I also tried reformat to (yyyy-mm-dd) via Behaviors Panel > WA Validation Toolkit > Apply Client Validations > Date/Time.
On form submission, displays "invalid format" and will not submit.
Attached is my code and screenshots.
Thanks for any help. D.
you will need to use the yyyy-mm-dd format for both the Client side validation and the spry Validation.
