Problem with Open_basedir restriction
Thread begun 1/04/2010 8:06 am by jonathan.meilleur385477 | Last modified 1/14/2010 4:02 pm by Eric Mittman | 4426 views | 6 replies |
Hi, I've search about the problem I have on your forum but cannot figure how to fix it.
Here is the PHP message :
Warning: main() [function.main]: open_basedir restriction in effect. File(/WA_eCart_Definition_PHP.php) is not within the allowed path(s): (/var/www/vhosts/seconcept.com/httpdocs:/tmp) in /var/www/vhosts/seconcept.com/httpdocs/WA_eCart/seconcept_PHP.php on line 2
Warning: main(WA_eCart_Definition_PHP.php) [function.main]: failed to open stream: Operation not permitted in /var/www/vhosts/seconcept.com/httpdocs/WA_eCart/seconcept_PHP.php on line 2
Fatal error: main() [function.require]: Failed opening required 'WA_eCart_Definition_PHP.php' (include_path='.:') in /var/www/vhosts/seconcept.com/httpdocs/WA_eCart/seconcept_PHP.php on line 2
Thanks for your answer and your great products!
JBWebWorks
if you run phpinfo()
the setting for
open_basedir should be
Local Value-----Master Value
no value--------no value
The error: 'open_basedir restriction in effect' indicates that the open_basedir setting in the php.ini is turned on which is used to restrict the locations that include files can be placed on the server.
If a file is uploaded to the server outside the locations specified by the open_basedir directive, you will receive that message. More information can be found here:
features.safe-mode
Thanks for your answers.
I looked with the hosting compagny and they said taht we cannot put the server php's in safe mode "off".
They want to protect the database of other clients.
Is there a solution to solve the problem?
This is very unusual for the host to not allow safe mode to be disabled, according to the php documentation in php 5 this is deprecated and will not be available in php 6:
Safe Mode is deprecated in PHP 5.3.0 and is removed in PHP 6.0.0.
When the open basedir restriction is in effect you can only include files that are within the location specified in this setting. It looks like it may be the temp file in your webroot that is allowed:
To know for sure you can create a php info page by adding this line of code to the top of any php page:
<?php phpinfo(); ?>
Look for the setting here, it is open_basedir. You should see the allowed paths in here, you will need to put any of the files that you want to include in here and adjust the paths accordingly.
I tried everything and nothing is working..
I've run phpinfo() and you're both right, the path is really:
and the master value is :
"no value"
So, I've created a folder (tmp) on the server and dragged all the files in it changed the path in my php files and nothing have changed...
What can I really do??
Thanks again
You will need to discuss this with your hosting provider because you will not be able to use any other folder for the includes. If they will not allow safe mode to be turned off then they might have some info for you on how you can make use of the directory that is in the openbase dir setting. If your host does not allow for include files to be used in php scripts I would suggest looking for another host.
