Can't process Payments
Thread begun 9/22/2009 2:21 pm by warrenphillips25336771 | Last modified 10/14/2009 1:33 pm by Jimmy Wu | 9305 views | 18 replies |
warrenphillips25336771Beta Tester
I have my store sort of set up right now, I have secured the pages that are needed, whe i add an item to the cart and click to go to the next stage, it redirects to me saying my cart is empty, any ideas?
the website is www.beadsandjewellerymaking.co.uk try adding a product and going through the checkout process.
quick note
it does add to cart but the cart seems to empty itself,
It looks like the items added to cart are lost when transitioning from the non-secured page to the secured pages. If you add the items to the cart while using the https, the items are added to the cart and retained when checking out. Is it possible to run the product pages and cart pages from the secure site as well?
Originally Said By: Jimmy Wu
don't understand why it would do that, surely this must be a bug with the solution, To run the whole site through the secure site will involve alot of work, according to the forums only 6 pages needed securing. Is there a work around on this?
still not working
Hi jimmy
ok so i changes the globals file and pointed it to my secure server, this did not work, any other ideas?
What is not working currently? Is it the same issue or is it a different issue?
the payment page is still not working, in the globals file i pointed the site root to the secure server like you said but it still goes to the unsecure side, other than that i do not want to go spending my day changing all the links on the site to include the https:
so if this does not work where do i go from here?
What settings do you have specified for these variables in the globals file: $WAGLOBAL_Root_URL, $WAGLOBAL_localRoot, and $WAGLOBAL_remoteRoot?
$WAGLOBAL_Root_URL = "https://web113.secure-secure.co.uk/beadsandjewellerymaking.co.uk/" ;
$WAGLOBAL_Site_Name = "beads and jewellery making" ;
$WAGLOBAL_Address = "Unit 2, CPS Center, Common Lane";
$WAGLOBAL_City = "Culceth";
$WAGLOBAL_State = "Warrington";
$WAGLOBAL_Zip = "WA3 4EH";
$WAGLOBAL_Country = "UK";
$WAGLOBAL_GoogleAPIKey = "";
$WAGLOBAL_localRoot = "/";
$WAGLOBAL_remoteRoot = "https://web113.secure-secure.co.uk/beadsandjewellerymaking.co.uk/";
It doesn't seem to go to the non-secure site when I test your pages, but the links are not going to the correct location. The links should be setup based on the global file settings.
Try changing the $WAGLOBAL_localRoot and $WAGLOBAL_remoteRoot to "/beadsandjewellerymaking.co.uk/" and see if this helps.
