Captcha Image missing
Thread begun 3/13/2010 2:36 pm by westmorelandgraphics311771 | Last modified 4/01/2010 6:44 am by Jason Byrnes | 6369 views | 8 replies |
I'm in the contactus.php file. The captcha image is missing and I cannot get it to work. I've checked the img src re: instructions from another post. Here is the code associated with the image:
<div class="text"><img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" /></div>
I've also tried changing the font in the WA_Globals.php file. What can I try next to get this to work? Thanks.
Denise
please post a link where I can see the problem.
Here's the link to the contact page:
contactus.php
when i view source of the page, the image source code is:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=F0F0F0&bgcolor=F0F0F0&textcolor=000000&transparent=0&characters=5&width=255&height=40&font=/ContactForm102/ContactForm_GMC/WA_ValidationToolkit/Fonts/MACTYPE.TTF" alt="security code" />
trying to browse directly to the captcha image at:
MACTYPE.TTF
gives the following error:
Warning: imagettfbbox() [function.imagettfbbox]: Could not find/open font in /home/denwest/public_html/store/WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php on line 125
seams there is a problem with the font path:
If I change that to:
font=Fonts/MACTYPE.TTF
and browse to:
MACTYPE.TTF
the captcha image displays correctly.
drewgss371883
Similar problem
I am having a similar problem.
I changed "font=Fonts/MOM_T___.TTF" but still get the Fatal error: listed below.
In the form I get a broken image link symbol in the captcha (contactus.php).
MOM_T___.TTF
Fatal error: Call to undefined function imagettfbbox() in /home/gssdesi/public_html/ContactForm_GMC/WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php on line 125
you need to enable the GD library on your PHP server
drewgss371883
Captcha image broken link
Still the same broken image links at:
contactus.php
contact_styled.php
Still the same error messages at all 3 links:
WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=000000&bgcolor=ffffff&textcolor=000000&transparent=0&characters=5&width=200&height=40&font=WA_ValidationToolkit/Fonts/MOM_T___.TTF
WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=000000&bgcolor=ffffff&textcolor=000000&transparent=0&characters=5&width=200&height=40&font=Fonts/MOM_T___.TTF
and GD Library is active see link below
gd-test.php
drewgss371883
line 125 from "WAVT_CaptchaSecurityImages.php"
$textbox = imagettfbbox($font_size, 0, $font, $captcha_string);
FreeType needs to be enabled as well.
See the php.net manual page for the imagettfbbox function
  Notes
Note: This function requires both the GD library and the ยป FreeType library.
In most cases, FreeType is automatically enabled with the GD library
