smtp authentication
Thread begun 9/04/2009 8:37 am by pascal267973 | Last modified 9/08/2009 9:05 am by Jason Byrnes | 4666 views | 5 replies |
pascal267973
smtp authentication
I need to be able to send emails with UE by connecting with an external SMTP server which requires authentication. At present, it looks like UE doesnt' support this as it assumes the SMTP server used will be the one where the page is hosted.
Is there a way to change the code so that I can submit a password as part of the SMTP authentication?
Pascal
What Server language are you using. In PHP, The Pear mail For SMTP Mail object gives the ability to pass authentication. In ASP, the CDOSYS mail object has the ability to send authentication to the SMTP Server as well.
pascal267973
Hi Jason,
Thank you for your response and for pointing me in the right direction. I use PHP.
Should the path to PEAR be the one for the server where the site resides or the one to PEAR on remote server where the SMTP settings are? I am assuming this should be the path on the site's server.
Best
Pascal
Yes, it should be the path to the Pear Installation on the Site.
pascal267973
Working great. Thanks Jason.
You're welcome.
