Admin log-in failure
Thread begun 2/08/2010 4:30 pm by beemerrider280362 | Last modified 3/05/2010 1:09 pm by Eric Mittman | 10432 views | 24 replies |
beemerrider280362
I just upgraded from version 2 to version 3 powerstore. I ran the script for updating the database and all of my inventory transferred fine. The front end displays as expected. But I cannot log into the back end. I checked in the database and the table wa_settings shows my username and password that I entered during the install. Yet when I use that username and password to log-into the admin area, it fails.
The ID's (line #) are 73 and 74 and the field names are admin_username and admin_password. So I'm pretty sure I have the correct table and field names.
The resulting URL after attempted log-in is: index.php?accesscheck=%2FAdmin%2Fhome.php
From what you have described it seems that the username and password are correctly set in the db. As a test of this you can put the attached file into your admin area and browse to it. You should only run this test locally, this file should not be uploaded to a live server since it will tell whoever looks at it the username and password for the admin area.
Please give this a try to see if the values match what you have in your db. Let us know how it works for you.
beemerrider280362
Values match
Yes the values match what is in the database. I tried logging in by copying and pasting the username and password just to verify my typing skills and still could not get in.
I have opened a ticket for you on this issue so that we can look into it further. To update the ticket login to WebAssist.com and visit your support history.
jmitchell66483
I am having this exact issue. I downloaded the file and the username and password are correct. but it will not let me in. Out of curiosity, where are the username and password stored?
jmitchell66483
Originally Said By: jmitchell66483
I scrapped everything and started all over again and I am still getting the same reqults. The login is not working.
I am only testing out powerstore3, but you can access it here:
www.powerstore3.com
Try logging in using
U: admin
P: bubble
You should check the db to see if things match up there. In the db you will find this under the wa_settings table, in the name column look for admin_username and admin_password, then check the value column for these two records.
One other thing you can try is to use another browser to see if you are having a problem based on the browser.
Post back and let us know what the result is, if we need to open a ticket I can do that.
jmitchell66483
I see it in there and it looks like the username and password are in the database. I tried the admin in IE and firefox and both fail on the login
I have opened a ticket for you on this issue, to update the ticket login and visit your support history.
tia371500
Login failure
I am having the same problem. Double checked the login info in wasettings table.... everything matches but I cannot log in.
By the way... the self installation feature ROCKS!... if everything else works like the docs say it should this will be the best $150 I have spent all year thus far...
Thanks WA
