Can get default zoom to work
Thread begun 2/08/2010 3:20 pm by flhomesites394744 | Last modified 2/16/2010 1:31 pm by Jason Byrnes | 3064 views | 7 replies |
flhomesites394744
I added the code to make the default zoom to work when the map opens but I cannot get it to work on one of my maps. My other maps work fine, but this one shows a gray screen.
Here is the page of code: wagmp_map_2.php
Thanks!!!
this is a link to the maps javascript file, can you post a link to the page you included the map in that does not work instead?
flhomesites394744
Here is the link to the page of the map:
meadows1.php
When I load this page, I get a an error saying the api key is for different web site. Please visit:
maps/
to generate an API key for your site:
www.primefloridaland.com
flhomesites394744
The API key is set for this page now.
The map will not display
meadows1.php
try re uploading the google_javascript/wagmp_maps.js file, it does not look like it was properly uploaded.
samratds349156
Hi
I am trying to set the initial zoom level so that the map zooms in london and doesnt show the whole world with UK .
How can I do that ,I have set the Country =UK and city = London and rest are picked from database.sometimes it is working some times it zooms in to UK map
mapsearch.asp
the default map that is used if the address look up fails is created by this code:
map.setCenter(new GLatLng(30, -98), 3);
you can change the latitude and longitude to 55.378051, -3.435973, this center the map on the UK:
map.setCenter(new GLatLng(55.378051, -3.435973), 3);
you can also modify the zoom setting:
map.setCenter(new GLatLng(55.378051, -3.435973), 7);
to zoom in a bit.
