Doube written Code?
Thread begun 2/08/2010 8:32 am by info400292 | Last modified 2/12/2010 9:41 am by Jason Byrnes | 2626 views | 4 replies |
info400292
Doube written Code?
Hello,
I am new to CSS Menu Writer and have the following problem:
I insert a menu to my Dreamweaver template. Then I modify it using the script button as described, I click on "Edit Menu". After my changes I click on ok. The changes are accepted but if I take a look into the html code I see that the section
<style type="text/css" media="all">
@import url("../CSSMenuWriter/cssmw0/menu.css");
</style>
is written two times, also the ie section is double.
What's wrong?
Thank you for help.
Thank you for bringing this to our attention, I have logged this in our bugbase so it can be corrected in a future update to CSS Menu Writer.
info400292
Ok, thank you.
And it seems that the path of the second written code is wrong (in my case it does not write the neccessary go back part (../). So it's easy to find and delete it.
thom389733
Ditto same problem
Having the same issue
for the time being, you will have to manually delete the duplicate code. I have logged this as a bug so it can be addressed in a future update.
