safe mode error
Thread begun 2/06/2010 2:09 am by ffiguerola395137 | Last modified 2/08/2010 11:23 am by Office Guy-172461 | 4392 views | 7 replies |
ffiguerola395137
safe mode error
This is the message I have when I try to find a image on the server, to download it and put in HTML editor.
" There are errors in your configuration or server. If the messages below describe missing variables, please check the supplied configuration.php.dist for notes on their usage.
* KFM does not work if you have safe_mode enabled. This is not a bug - please see PHP.net's safe_mode page for details"
I can't understand what is the problem and how to solve it. This doesn't happens in my local server - managed by MAMP.
Could anyone help me?
Thanks in advance.
Office Guy-172461
You could try putting this:
php_value safe_mode off
inside the .htaccess file to turn it OFF.
Some hosting panels also have a place in the options section for turning safe mode off. It all depends on the hosting company. Some will take the time to secure their servers properly, and others use the shotgun approach and restrict anything that might cause a problem. The cheaper the hosting, the more restrictive they tend to be.
ffiguerola395137
Originally Said By: Office Guy-172461
¿Where can I find the - htaccess file?
ffiguerola395137
Originally Said By: ffiguerola395137
Sorry Guy I miss to thank you your replay
Office Guy-172461
If it doesn't already exist you can create one with a text editor.
Have a look here:
.htaccess file with examples - Beginners guide
162
Office Guy-172461
I just updated an article on the .htaccess file:
123/
ffiguerola395137
Solved
Thanks Guy for your help. I've my problem solved. It was about my server parameter. When I explained it to the server manager's enterprise they change the php secure to normal and tha's all. It works.
Thanks again
Office Guy-172461
Good to hear. Thanks for posting back the results.
