Theme-It Build 009 Beta Available for WCE
Thread begun 2/05/2010 2:23 pm by Justin Hood | Last modified 2/05/2010 2:23 pm by Justin Hood | 522 views | 0 replies |
Justin HoodWebAssist
A zip file will be emailed to you today, containing Theme-It Build 009 (Beta).The beta build is only available to the WCE group so please do not report bugs or feedback in the regular support forums; use this forum to provide us input or ask questions.
The serial number for this group is h0sEH-A5RsP-0x2nB-r2Ltr. There are a limited amount of activations so please do not install on more than 2 machines. This serial number will work until it goes live in early March. Post here, if for any reason, it doesn't work before then.
Thank you all for the great reporting thus far. Keep it coming!
Please start a new thread when submitting feedback. Thank you.
Items addressed in 009:
*Splash/About screen updated.
*'Revert Back' button added. It is now possible to revert back to a state prior to modifications made by Theme-It.
*Changes made to some image field values are not being retained after clicking the vertical scroll bar.
*onLoad 'imageURL has no properties' error occurring when launching Theme-It.
*Corrected an issue that made it difficult to click the Move Up / Move Down buttons in the color list.
*Corrected an issue that caused the incorrect attribute to be modified when changing the ALT attribute value in Theme-It. This was occuring when other attributes contained the same value as the ALT attribute (example: insert="thisvalue" alt="thisvalue").
*Corrected an issue that prevented changes to ALT field values from being retained after clicking the horizontal scroll bar when managing images.
*Corrected an issue that caused an onLoad error to occur when inspecting a page that used short CSS syntax such as: background: #ffffff;
*Design colors are now generally listed from lighter to darker instead of the frequency a particular color was used.
*CSS elements that use the same color are now broken out into seperate listings for text, background color, and everything else.
