Beta Glitch
Thread begun 2/04/2010 5:55 pm by neo314 | Last modified 2/08/2010 11:06 pm by Dani Chankhour | 2984 views | 6 replies |
neo314
Beta Glitch
Updating iRite instances does not always remove the WA_iRite include which breaks the page until you find the problem. I am also seeing some instances where the custom toolbar does not exist problem occurring after updating an instance. The first couple went fine, so it may be related to whatever bug also prevents the include from being removed.
Other extensions may have pushed the WA_iRite include further down in the code which may be confusing the update process. The GUI was so buggy, I probably manually inserted the include myself to apply WA_iRite to these pages.
neo314
Well it was not the position of the include because it just did the same to one where the include was right at the top of the code.
Dani Chankhour
Yeah, the position of the include should not matter. It should always remove the WA_iRite include.
If possible, could you send me the page with the iRite instance on it (if you have a copy), to see if i can reproduce the issue?
neo314
How should I send it to you? Open a ticket? I need to retrieve it from a backup since I have already updated the pages, but it shouldn't be a problem.
Dani Chankhour
If it is possible to retrieve it from a back up, you could just send the page as an attachment to this thread after you zip the page(if that is OK with you).
neo314
I have not looked at these pages right off, but I generally don't post developed pages where there is server side code in a public space. This is a live site. I would rather send them to you directly.
Dani Chankhour
I have opened a private support ticket to further look into the issue.
