dreamweaver shows different map
Thread begun 2/04/2010 1:40 pm by flhomesites394744 | Last modified 2/05/2010 10:56 am by Dani Chankhour | 1389 views | 1 replies |
flhomesites394744
when I test server the page, the correct map shows, but when I go back to edit in dreamweaver the same incorrect map that was installed using the program shows up again. How can I add addresses to my map with the wrong map showing in edit?
Also this page in dreamweaver does not have the edit google button (I know the map does not show in the website because I have not entered the correct api key yet
heights1.php
Dani Chankhour
Is your testing server local or is it on a live server?
If the testing server is on a live server you might want to download the google_javascript folder from your testing server to your local files in DW.
I got the source from your page and i was able to edit the map on your page, however i think you are using an older version of pro maps for google. I recommend that you install the latest version from your download center (1.0.6), and try reapplying the map to your page.
