add to cart error
Thread begun 2/03/2010 1:18 pm by stuff223820 | Last modified 1/31/2012 11:41 am by Jason Byrnes | 6470 views | 10 replies |
stuff223820
add to cart error
all worked fine before and now i get this error when i add an item to my cart:
Warning: Missing argument 11 for WA_Store_Cart_Definition::AddToCart(), called in /home/xxxxx/public_html/xxxx/Products_Detail.php on line 124 and defined in /home/xxxxxx/public_html/xxxx/WA_eCart/WA_Store_Cart_PHP.php on line 28
Warning: Missing argument 12 for WA_Store_Cart_Definition::AddToCart(), called in /home/xxxxxx/public_html/xxxx/Products_Detail.php on line 124 and defined in /home/xxxxxx/public_html/xxxxx/WA_eCart/WA_Store_Cart_PHP.php on line 28
Warning: Cannot modify header information - headers already sent by (output started at /home/xxxxx/public_html/xxxxx/WA_eCart/WA_Store_Cart_PHP.php:28) in /home/xxxxxx/public_html/xxxx/Products_Detail.php on line 140
any ideas?
stuff223820
forgot web address
store.strikephoto.com
Jimmy Wu
What kinds of changes did you make before the add to cart button stopped working? Also please send me the line of code that the error is referring to so I can take a look at it.
stuff223820
i changed my server to a dedicated IP. but that really has nothing to do with it i am sure. deleted and reposted all my files on the server. It is weird because it still works perfectly on my local test server. The add to cart button still works. You can add an item, but it jsut won't go to the "cart" page. If you choose "view cart" in the upper right menue. The items are there and it all works fine.. just gets stuck when you hit "add to cart"
Line 120 to 144 of products_detail.php:
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$WA_Store_Cart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemThumb, $ATC_itemSKU);
if ($ATC_RedirectAfter != "" && $WA_Store_Cart->redirStr == "") {
$WA_Store_Cart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($WA_Store_Cart->redirStr != "") {
header("Location: ".$WA_Store_Cart->redirStr);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/Main.dwt.php" codeOutsideHTMLIsLocked="false" -->
stuff223820
line 24-29 of wa_store_cartPHP.php :
return -1;
//end node
//start node
function AddToCart($AddIfIn, $RedirectIfIn, $itemID, $itemName, $itemDescription, $itemWeight, $itemQuantity, $itemPrice, $itemThumb, $itemSKU, $itemSize, $itemColor) {
if (get_magic_quotes_gpc()) {
stuff223820
help still needed on this one please
Jimmy Wu
It looks like the items are still added to the cart. Have you installed and run eCart 5 for anything on the PowerStore page? The AddToCart call has more parameters in the eCart 5 definition. If you revert the wa_store_cartPHP.php file to the one provided in PowerStore, this should fix the issue.
stuff223820
that was exactly the problem and yes, i did open it up in ecart 5 to poke around. your fix worked.. thanks Jimmy!!!
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
afeliksas433126
Definition file for this eCart object was not found
I have created product Results and Detail pages using DataAssist.
on Detail page inserted Cart Object and add to cart button.
It seems it works fine but every time I open the page on Dreamweaver, access Server Behaviors/Bindings tabs it gives a warning:
"The definition file for this eCart object was not found".
On Server Behaviors tab there is Server behavior "! eCart Object ()" . If I try opening it gives another warning:
While executing timer in WA eCart Object.htm, the following JavaScript error (s) occured:
At line 230 of file ".......\WA eCart Object.js": document.generalWP. document.objPersistance.options[OBJECTEF.Persistance] has no properties.
I've tried deleting and running the wizard a few times but I get the same every time.
I've attached the scrip.
Do you know what the problem is?
