Sorting add options
Thread begun 2/03/2010 1:02 pm by jaa397769 | Last modified 2/17/2010 3:08 pm by Eric Mittman | 4931 views | 14 replies |
jaa397769
Sorting add options
I am still unable to sort out my add options in admin backend. For example, I enter
Small, Medium, Large, X-Large, XX-Large and my results are always out of order. For example Small. Large X-Large Medium, XX-Large.
I did what I was explained to do in my last thread, but the results are still the same. Please help out guys, my customer is getting impatient, and I don't blame him, he just wants to see things sorted as their inputed to the back end of his shopping cart.
Thank you I appreciate your quick response.
What part of the site are you referring to when you say the results are out of order? Is this on the front end of the site where you are selecting the options or on the back end where you are setting things?
Also, what was the solution you tried, do you have a link to the thread you were working with?
jaa397769
Sorting add options
Hi Eric, thanks for getting back to me. It's on the front end. It will not lay out right on the page no matter what I've tried.
I added a table to "options" called optionsgroupdate and set it to Timestamp "CURRENT_TIMESTAMP"
that didn't do anything
I also to out the data in the quotes on the SQL statement that was refered to in another thread.
that didn't do anything.
I just want to simply add my options in the backend such as
small, medium, large, x-large, xx-large and then have it seen like that in the drop down on the front end. I would imagine this is a pretty easy fix. Please advise.
Thank you
By default the options are listed by the name of the option. This is controlled by the query on the product details page on line 429. In this query you can update this order by to be based on the id of the option, this will list the options in the order they were added to the db.
The end of line 429:
ORDER BY OptionName", GetSQLValueString($OGIDParam_OptionValues, "int"));
Update it to be like this:
ORDER BY options.OptionID", GetSQLValueString($OGIDParam_OptionValues, "int"));
Give this a try and let us know how it works for you.
jaa397769
This is how it reads now
Do I change this part here,
".$AddToWhere."", GetSQLValueString($OGIDParam_OptionValues, "int"));
to
".$AddToWhere."ORDER BY options.OptionID", GetSQLValueString($OGIDParam_OptionValues, "int"));
jaa397769
Thank you Eric
I got it to work, thanks a lot Eric. Now if we can get that secondary pricing to work, it would be real good. The thread you responded back to me on, I was a little confused by what you were saying. I guess I'll go to that thread an explain what doesnt' make sense to me.
Thank you again.
I'm glad you got it to work out. Just for any others that come across this it is not the '$AddToWhere' part of the code but the query code you see just after this.
I will keep an eye out for your other thread.
cj.tung395641
Hello,
I have changed the order code to
unfortunately this action creates a lot of problem to me.
on the page Products.Detail.php the option presented like what I need
eg., size (the order I insert in Admin)
S
M
L
Colour
White
Red
Black
but
when I try to choose Size S + Colour Red, on the name of product came up Size M + Colour Black
also
I even deleted this product and insert completely again, but still came out the same problem
I notice that when I edit product with a combination of options in Admin, the URL shows for example ProductID=1100
but when I choose the product with the same options combination in Products.Detail.php. the URL doesn’t change but remain the old ProductID=1090.
Then I enter the new ProductID=1100, the product shows up correctly.
Can anyone tell me what is the problem here? THANK YOU
Here is the website product page
Products_Detail.php?ProductID=6
I was not able to get this part worked out, it seems that there are a couple other recordsets involved on this page that might need to be adjusted. I tried to make the adjustments and was not able to get it worked out. I have opened a ticket for you on this issue, to update the ticket login and visit your support history.
cj.tung395641
Hi Eric,
I have login and update the ticket yesterday, but seems no engineer reply me yet. How long does it take to reply question usually? Thank you.
