Empty cart on Submit
Thread begun 2/03/2010 12:48 pm by denise234045 | Last modified 2/05/2010 2:24 pm by Jason Byrnes | 5637 views | 9 replies |
denise234045
I have no idea how to go about fixing this.... it appears that a large number of our orders are not going through. When users click on submit they are redirected in some cases to an empty cart w/out going to authorize.net at all!!
It doesn't seem to be a problem on macs - but right now I can't get athorize.net transactions to go through on my pc at all.... the paypal option works fine.
The site is
www.intlarrivals.com
I've also had issues with email confirmations not confirming - even though users click on the link to confirm - on their profile page it remains saying that they have not confirmed, no matter how often they try.... it doesn't always happen and I gave up trying to fix it. Just mentioning it here in case its somehow related.
Globals:
$WAGLOBAL_Root_URL = "http://www.intlarrivals.com/" ;
Help is most appreciated as this site is very live......
I am not able to reproduce the problem, the transaction went to the checkout failure page because I entered a bogus cc#.
Make sure when you are testing that you are not starting at:
intlarrivals.com
Without the www, this is considered a different domain and the cart will be emptied when the checkout cart page redirects to:
checkout.php
also make sure you have cookies enabled in the browser, if cookies are not enabled, the session will not be stored correctly.
denise234045
Yes - I'm doing it from www.intlarrivals.com (but certainly with my track record, is worth checking! :-)
The problem is when on the 'confirm.php' page - once the submit button is pressed the site redirects to 'cart.php' - and its empty.
As I said before it seems to be working fine from my mac?!
I'm not sure where to start looking
FYI - On your site I tried to take a look at : Customizing the WA_Globals.php file (PDF)
but got this error message:
NoSuchKeyThe specified key does not exist.how-tos/sp_ps_globals_2.pdf290D001053A6714AfsH9U/K2jwuijGGZBbcDI5h+pijfOWvLBKj9yhtWOeLMk5aKTRJL0euPBti1qEGn
I have $WAGLOBAL_remoteRoot = "/";
Is that wrong??
Could it have to do with sessions...
Cookies ARE enabled. The site has 3x's more registered users on the site than actual customers and there is no reason for someone to register w/out making a purchase, so this is of great concern....
As always, thanks for your help. Its greatly appreciated!
Denise
find the following code on the confirm page:
if ($WA_Store_Cart->IsEmpty())     {
$WA_Store_Cart->redirStr = "cart.php";
$WA_Store_Cart->cartAction = "RedirectIfEmpty";
and change it to:
$WA_Store_Cart
->GetContent();
if (
denise234045
Sorry - that doesn't work either...
Attaching confirm.php in case that's helpful.
Thank you SO MUCH.
here are a couple other things to tryL
1) On the confirm page, find the following code:
// WA eCart Redirect
if ($WA_Store_Cart->redirStr != "")     {
header("Location: ".$WA_Store_Cart->redirStr);
and change it to:
session_commit();
2) on the checkout success page, find the following:
if (!isset($_SESSION['OrderID']))     {
and change it to:
if(!session_id()) session_start();
if (!isset(
$WA_Store_Cart->redirStr = "cart.php?oid=0";
if you are still directed to the empty cart page, check the address bar and let me know if the address includes the querystring "cart.php?oid=0"
denise234045
That didn't work either.
But yes, I was directed to "cart.php?oid=0"
Does oid stand for orders in database??
Thank you...
One of the last code changes was to add oid to the querystring so in the redirect onthe checkout success page, I had you do this so I could see if the redirect was happening on the success page or not.
So now we know the redirect to the empty cart is happening because of this code on the success page:
The redirect is occuring because $_SESSION['OrderID'] is not set, this is set by the Store Order Summary Behavior on the confirm page.
can you double check in the database to see if the order information is being stored.
denise234045
No, I don't think it is. I see in the db that there are 34 orders - which is the number of orders that have been processed and gone through.... none of these orders that redirect to the cart page are there.
login.php
