Change USD to URO in Admin orders chart (monthly and daily)
Thread begun 2/03/2010 6:03 am by cj.tung395641 | Last modified 2/04/2010 2:21 am by cj.tung395641 | 4614 views | 3 replies |
cj.tung395641
Hello,
As this message title, I would like to know how to change USD to URO for the revenue chart.
Thank you.
cj.tung395641
I am using PowerStore v2, and I found some answer from other thread reply.
In my order_Chart_Daily_data2.php I have changed the <tooltip><![CDATA[#x_label#<br>Revenue: $#val# ]]></tooltip>. to &#8364;#val#
And also try to change in order_Chart_data2.php, but seems dosent work at all.
Could anyone give me idea?
Thank you.
make sure you also change this in all of the web charts data pages:
<pageName>_data<int>.php
you may also need to clear the browsers cache, close the browser and restart it.
cj.tung395641
I have changed two parts in all the data2.php pages of the DynamicWebCharts/Data folder, and it finally worked. I can not find $ next to #val# in data1.php pages, so I did not change data1.php.
1. Change <yaxis color="#767a7f" gridcolor="#888d93" format="$#val#"> to format="EUR#val#". (tried with &#8364; and &euro but failed)
2. Change <tooltip><![CDATA[#x_label#<br>Revenue: $#val# ]]></tooltip>. to EUR#val# (also tried with &#8364; and &euro and failed)
In revenue chart it shows EUR (instead of the Euro symbol).
I would like to suggest that maybe the Flash chart size can be a bit bigger. Sometimes the floating message is longer than the chart. Thank you.
