PowwerGallery not previewing any gallery on control panel
Thread begun 2/03/2010 4:08 am by miguel398317 | Last modified 2/23/2010 3:01 pm by Jason Byrnes | 3970 views | 6 replies |
miguel398317
Hi, i have tried to install PowerGallery on 2 different computers (Vista Home Premium, Windows Server 2008 Web Edition), installation wizard finishes correctly, but when you try to preview any of the galleries, within the control panel, THEY NEVER END LOADING... Could you please help me? Thanks.
Hi, finally i fixed the problem, it was following:
First I installed the PowerGallery inside a localhost:10001 website... ( i use these ports to use several "localhost" websites) and it did not work...
Then I just changed the installation to a localhost:80 (Default Website in IIS 7.0) and... Now its working fine!
Thank you very much!
Jimmy Wu
What hosting provider do you use for these galleries? Can you post up an example of a page you've applied the gallery to?
miguel398317
Problem fixed!
Jimmy Wu
Great to hear you were able to get this working. If you run into any additional issues, feel free to open a new thread.
sam.wilson394782
Same Problem
Hi my first post here! Ive just bought the solution suite and subscribed to the extenision library, anyway to the point now -
Ive installed PowerGallery to my local xampp server with the path localhost/test/gallery and everything seems to be working correctly (adding galleries / uploading images etc). The problem comes when I try to preview a design through the 'choose gallery' page.
I click the preview link, it then in turn opens a blank window and then nothing??
This also happens when inserting the php into a page and then try to preview it.
pretty much the same problem as above but cant work out how to get around this?
can anyone help?
thanks
miguel398317
There is still an issue in Powergallery installation wizard...
Hi again to everybody!
I have noticed that when i install Powergallery on any domain content folder using Plesk 8.6, something during the installation process doesn't work properly, and the url's generated in "add to site" are wrong.
It only works (the preview of the galleries) if i install Powergallery inside a site or just directly USING THE DEFAULT WEBSITE ON THE LOCALHOST:80, but installed on any other site or port IT DOESN'T WORK THE PREVIEW OF THE IMAGES AT ALL, it doesn't matter if you use the direct link, if you embed the code into a php page, or you try to preview in the option "choose gallery"...
Then, if i want to use the Powergallery inside a web using a domain, I HAVE TO USE FOR THAT DOMAIN THE CONTENT FOLDER OF THE PREVIOUS INSTALLATION UNDER THE DEFAULT WEBSITE ON LOCALHOST:80
I have tried to set up another site with the same bindings as the THE DEFAULT WEBSITE ON LOCALHOST PORT 80, BUT IT ALSO DOESN'T WORK (THE PREVIEW OF THE IMAGES...)
So with the actually conditions, I CAN USE ONLY POWERGALLERY EXCLUSIVELY FOR ONE DOMAIN IN A SERVER, BECAUSE THE PREVIEW OF THE IMAGES ONLY WORKS UNDER AN INSTALLATION MADE ON THE DEFAULT WEBSITE ON LOCALHOST PORT 80.
SO I SUPPOSE THAT SOMETHING MUST BE WRONG WITH THE INSTALLATION WIZARD OF POWER GALLERY.
THANKS.
login.php
