no database selected message
Thread begun 2/02/2010 4:20 pm by studio366170 | Last modified 2/03/2010 10:29 am by Jason Byrnes | 1520 views | 1 replies |
studio366170
When I view the page online it does not display half of the page (it displays perfectly on my mac though?) and says that no database is selected... but I thought I was doing that when I worked through the pdf tutorial?
Please help! I am in need of help fast!!
you need to first create the PowerStore database on your Hosts MySQL Server, Then Update the connections/localhost.php file to connect to the hosts MySQL server.
Your host should have a panel that allows you to access the MySQL server, most likely using PHPMyAdmin. using this tool, you need to create the PowerStore database using the database/store.sql file. Your host should also be able to give you the correct settings for connecting to your database, you need to update the connections/localhost.php file to use the correct settings to connect to the database on the hosts mysql server.
