Need to modify cart's tables and shipping with e-cart
Thread begun 2/02/2010 7:18 am by John_GR | Last modified 2/03/2010 3:03 pm by Jason Byrnes | 1826 views | 3 replies |
John_GR
Hello
I am really desparate trying to make things work since a lot days...
I am a designer with no coding experience and i would really appreciate it if the replies to this thread would be as simple and straightforward as possible...
I purchased powerstore 2 in order to make an e-shop for a client. The problem is that we are in Greece so i had to modify some of the features of powerstore, such as shipping etc.
After feedback from the forum i purchased e-cart 5.
A. What i need to do is to apply some flat shipping rates.
for example :
-if the total weight of products is less than 50 kg, the shipping is 20euros etc.
I have no problem crafting these rules but i
after crafting them, the shipping cost is not visible at the cart page.
I haven't made any other modifications to the files... the only thing i did was:
1. opened the cart.php file
2. i edited the WA_Store_Cart file and changed currency to euros, kgs and made the shipping rule.
3. I removed the FEDEX, UPS and UPS shipping rules.
4. I uploaded files to the server. (you can check at: index.php )
When i add products to the cart, there is only the total cost...
I now i have not done something that i should have.
B. I notice that:
At the cart page, there is not a column for total weight... I wonder if there must be a column for the weight of each product for the shipping rules to be effective...
If there must be this kind of column, how am i supposed to create it?
Is there some kind of code i must add? Could you please send me an example code if needed?
C. Also,
Are there some settings i have to enter to the globals file for bypassing the ups, fedex and usps shipping rates calculation?
Please, if there is someone that can help me with this issues, provide a non techy and straightforward solution, i am really in big trouble with my client, because i'm way off the deadline trying to make things happen.
D. Last but not least, the changes i need to do at the cart page, or anywhere else, are they going to affect the checkout procedure in any way? are there certain things i must notice?
For your reference i include the cart.php file, the cart definition and the storecart files, as well as a couple of screenshots from the shipping rules interface and the cart's tables.
Any help would be much appreciated...
on the cart.php page, the row for showing the shipping has been removed.
find the following code:
//WA eCart Merchandizing Show End
  //ecart="WA_Store_Cart"
//WA eCart Merchandizing Show Start
if ($WA_Store_Cart->GetCharges() > 0)     {
            <tr>
              <th>Charges:</th>
              <td><?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->GetCharges()); ?></td>
            </tr>
if ($WA_Store_Cart->GetTax() > 0)     {
            <tr>
              <th>Sales Tax:</th>
              <td><?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->GetTax()); ?></td>
            </tr>
and change it to:
            <tr>
              <th>Charges:</th>
            </tr>
if ($WA_Store_Cart->GetShipping() > 0)     {
            <tr>
              <th>Shipping:</th>
              <td><?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->GetShipping()); ?></td>
            </tr>
            <tr>
              <th>Sales Tax:</th>
            </tr>
if you do not wish to use shipping rate lookup, disable shipping in the WA_Globals:
$WAGLOBAL_Shipping_Enabled = false;
John_GR
thanks jason
it works. Seems it had been removed by accident...
glad to hear it is working.
